First MPG calculations in lifted brat
Hmmm did afew rough caluations at the gas station today... 5.2 or so gallons... around 35 miles.. (larger tires on the car, so I probably drove 40-something miles really. But thats 6.7 MPG x the multiplier for the tires...
Now.... why do I think its so low?
I spilled ALOT of gas changing the fuel filter and the vapor separator, AND the carb was just rebuilt.
Also the fuel line that goes in the top of the separator is leaking a bit... just afew drips here and there, but it adds up. Gonna change it monday. I'm hoping for at LEAST 15 MPG before tire multiplier. Hopefully I dont spill too much when I change that fuel line so as to keep the calculations as accurate as possible.
What is everyone else getting with webered EA81's with big tires?
(engine is tuned up and carb was rebuilt so I think my leakage is the only problem here... the car runs great)
I'm not sure if it makes a difference, but you multiply the miles to compensate for the tires, than divide by the gallons...mine's about 20% (same as speedo, so if you barrow a GPS, or match speed with another car at 50, you can figure it out that way), and that get's me about 20 mpg @ 75 mph, 24 @ 60, and 22 city...
Mine gets like 26 pre calc... I actually had an issue where I had been running my SPFI O2 sensor free, then I put one in and I got like 80 miles to that tank where I usually get almost 300.... reset the comp and its back to where it was! My wagon rocks:brow:
My Old Wagon On Interstate Got From 22 To 28 Mpg With 6 Inch Lift Ea81 Carb W/ No Emmission Parts Left On It AND MECHANICAL 2nd barrell, Good Cat, 2wd Disty. Ngk Plugs, Accell 8.8mm Wires. 10w30 Castrol Syntec. 4 Speed High/lo Trans. 1981 Wagon. 91 Octane. Datsun T-case. 32x11.50x15 Swamper Sx
I Miss My Old Car:(
my wagon get 22-24 no matter how i drive it
oh brad if you miss it so much go drag it out of the junk yard
have to get it from ned....he doesnt seem to want to sell it back to me...:(
Ned's just letting it rust down and the longer it sits the beat and bagged up it gets the whole pass side rear quater is smashed in the rear glass is busted out it needs to be saved or there want be anything left of it
i figure mine out once when i had my buckshots on, it was around 15 mpg. i used n my gps to get the miles i drove and used that to figure it out with. i figured its not good but not bad. need to do that with my new tires to see were i'm at now. new carb and new motor would probably bring my milage up.
