XT alternator?
All XT's are oddballs. The alt may work, may not. It may have a serpentine pulley on it, which will have to be changed. Or the mounts may be different. You will only know if you have it there to compare.
Really?? I guess I've just been lucky then
I stand corrected!! thanks!
you can use an XT unit if you are willing to modify it a little.
the mounting points are not quite the same and will require a small bracket to be fabricated on the adjustment side. the pully spacer needs to be machined down a bit. at least thats how it went on my wagon.
the amperage is greater than the stock one but not as much as the XT6 unit. I think mine tested somewhere around 60 amps my stock unit was only about 45amps.
