October 2, 200322 yr What is a Brat rear bed cover worth used but like new condition???? Snaps snap into the chrome moliding not the body??
October 3, 200322 yr I payed $110.00 for mine brand new at the same time I bought mine 84 Brat brand new back in 1984 If you found one theres a rubber strip on the front edge of the tonnue that will run a long under the rear window and you should also get the track the the rubber will pinch into you will need to mount that just under the window there is also velcro that needs to be mounted on the sides on the in side of the bed oppiste of the BRAT logo the snaps go with the exsisting screws in the crome trim and new ones will be mounted in between them theres also a suport rod that runs from side to side above the wheel well and below the crome strip on the inside of the bed this prevents saging does that help Hassey
October 3, 200322 yr They are worth a decent amount if in good shape as they are pretty rare.... $100+ I'd say
October 4, 200322 yr Just make sure that all the hard ware that i mention above come with the tonnue cover your looking at exspeaily the rail below the rear window you will diffenantly need that the snaps you can pick up at an upolstery shop
