November 28, 200520 yr Our 2003 Forester makes a dog-whistle-ish noise right after its shut off. Not really sure how long it lasts but (never stood there and waited) but I have heard it still going a while later. Anyone have a clue? A solution? Thanks, Steve
November 28, 200520 yr its saying WAAAAAAAAAAAAA DONT LEAVE ME!!! its a vacume resevoir with a leak, my firts guess. Can be the booster, can be the small can that is there for the HVAC controls. Pop the hood next time you park then shut the car off, and listen nipper
November 28, 200520 yr Author Perhaps it simply is lonely for the open road, and wants to keep driving? LOL! It's a non-turbo 2.5X. Will do on the open hood/listen.
November 29, 200520 yr LOL! It's a non-turbo 2.5X. Will do on the open hood/listen. Take a spray bottle of water with you and spray the usual suspects while it is whining (or a can of WD-40, if you want). the part you spray that stops the whining, is your prime suspect the next time, until you find the part that stops it all the time. Then you know where the leak is, and can start on making the leak stop. . .
November 29, 200520 yr well you can also do this with the car running, as the engine rpm will change when it sucks in whatever your spraying. nipper
November 29, 200520 yr Our 2003 Forester makes a dog-whistle-ish noise right after its shut off. As has been mentioned already, this "sounds" like a vacuum leak or some sort of pressure equalization happening. Spraying a fluid at suspected areas may or may not help localize the culprit. Since the noise is evident with the engine off, it's probably safest to work that way. First try to get a sense of the general area the noise is coming from. Then, a tool I've used that often helps to home in on things like this is a stethoscope, or something equivalent. A piece of tubing (vacuum hose, etc.) works well; just hold one end to an ear, and move the other end near the apparent source. You'd be amazed at how much easier it often is to pinpoint the sound that way. --OB99W
November 30, 200520 yr Ranger, do you pass those shirts out to the drivers that cannot keep up with you ?
