Lookie what the man in the big brown van dropped off!!!
Oh yeah!
Resurfaced, Valve Grind, Cleaned and SHIPPED for $199.00, WITH a 1-year warranty :headbang:
Question:
When I install the head bolts, should I coat the threads? Usually I use HighTack gasket sealant (GM applications). What would you recommend?
they look very clean :banana:
Sorry, got no help for you :( just thought I'd say, good luck :D
From wherest did the big brown van cometh?
light machine oil
I do this as I do not want metal to metal friction
compromising the torque value
+1
Also, if you are reusing head bolts, do yourself a favor and clean them with a wire wheel first.
Yes, EA82.
I got them from J&C Machine in W.Virginia. They do TONS of soob work.
Machine oil huh? In that case won't regular motor oil work (obviously not glopped on).
I use a light coat of motor oil. When you oil head bolts, you need to be careful, because it's really easy to overtorque.
wow i gues i have never seen a bair ea82 head.. looks more like an ohv rather than an ohc. cool:)
That's 'cause the cam towers aren't on them. There's not much that's prettier than clean, freshly machined metal. :grin:
