Hi guys,
What sort of signal is given by the knock sensor....? Is it a constant voltage? How does the signal change when it senses a ping?
Can I trick the ECU into thinking there is a knock sensor connected....(I know its not advised etc, just need the info)
Thanks in advance
Paul
Thanks guys.....
I wanted to run my engine without the sensor due to the fact that I don't actually have a sensor......yet.
I have just finished rebuilding a wrecked engine and am still in the process of sourceing all the sensors.... I'm a bit over it, so am getting a little over eager.
I will take a chill pill and source a sensor.
Cheers
Hi guys,
If you leave it disconnected the ECU will pull timing and set a CEL. You will get poor milage and power but it will run.
