February 6, 200620 yr in my 84 4x4 wagon gl im getting 15 mpgs. and wont to get at 20mpg or so. i have a weber carb 32/34 also i put a different disteriber on. now what can i do with out loosing to much hp so if you have way to fix it let me know dennis
February 6, 200620 yr in my 84 4x4 wagon gl im getting 15 mpgs. and wont to get at 20mpg or so.i have a weber carb 32/34 also i put a different disteriber on. now what can i do with out loosing to much hp so if you have way to fix it let me know dennis i got 24 on the last tank is this considered good, average??
February 6, 200620 yr hmmm...25 mpg sounds about average for a 5 speed will get less with an auto (3 speed)
February 6, 200620 yr 15mpg is WAYYY too low for any tranny - ususally there is no more than 3-4 mpg difference between auto and manual - I would recommend that you check to see that the Weber is jetted right for your car, that would cause it to run richly - also if the choke is sticking, or the timing is wayy off - I have a good friend that got ~24-28mpg in town on his '84 with the D/R 4-speed 4WD tranny (better mpg on highway) - it also had a weber carb if you are running so rich you are getting 15mpg, you are actually losing power and a lot of it; peak hp output is obtained by a correct mixture (~14.7:1 air:fuel), not by putting in a ton of gas - you should notice a power, and fuel economy increase with proper adjustment just out of curiousity, what disty did you use, and what did you set the engine timing to?
February 6, 200620 yr I get 25 - 28 regularly with a Weber on my EA81 (stock height, 85 Brat). 15 is much to low. I would run a compression check, and read your plugs to get an idea if you are running rich or what's going on. Also make sure you have NO exhaust leaks - that will hit your mileage a bit as well. GD
February 6, 200620 yr Author the jets in the weber are right ones. iv leaned it out so its not runing rich it dose not smoke and has power. i just checked my compertion and i had 175 psi give or take i put a ea82 y pipe on it and then its a strat pipe rest of the back could that be part of it, also i dont have any DEQ crap on it so no egr vavle and stuff like that
February 6, 200620 yr Ok - lets start from the beginning - what math are you using to calculate our mileage? Better yet - how many miles do you get on a tank? GD
February 6, 200620 yr Author at the pump i put about 12gal of gas i get anywhere from 180 to 200 miles on that tank i started to 92 octan in got more power but the same mpg
