Power steering..?
Actually, yes - it's been done. The pump will bolt in, you just have to figure out the belt situation - the alt is used as the tensioner in the EA82, so you may need to measure and find a belt the right size. Just a V belt tho so shouldn't be hard at all. Measure with some string.
Might need to find or fabricate the mount for the pump from an EA81T tho....
If you're thinking about kludging an EA82 pump on there, why not just save yourself the trouble and leave the pump out completely? Although my '84GL had a power steering pump, it was disconnected (no belt, no hoses). Still seemed to work fine.
Um.... because it wouldn't be "power" steering then would it? Power is awesome for off-roading with lifted soobs. Much superior to manual.
Not a kludge either - the EA82 pump is the same as the EA81 turbo pump, so not all that strange to consider doing this.
