wallaceg Posted March 7, 2006 Share Posted March 7, 2006 I get a ticking/rubbing/grinding sound from the front drivers side some days in the morning. Sounds like maybe a bad CV joint, but it is not affected by making turns in either direction and the sound goes away after about a mile of driving. Is this a CV problem or could the sound be from the pads rubbing against rust on the rotors or something like that? If the sound goes away quickly, should I be concerned? The car is a 97 Impreza 2.2 4EAT w/ 87k. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 7, 2006 Share Posted March 7, 2006 I get a ticking/rubbing/grinding sound from the front drivers side some days in the morning. Sounds like maybe a bad CV joint, but it is not affected by making turns in either direction and the sound goes away after about a mile of driving. Is this a CV problem or could the sound be from the pads rubbing against rust on the rotors or something like that? If the sound goes away quickly, should I be concerned? The car is a 97 Impreza 2.2 4EAT w/ 87k. Check the brake pad wear indicators first - they can be intermittent before they start squealing regularly. Also check for the caliper to be free to slide on the pins. Quote Link to comment Share on other sites More sharing options...
TheYeti Posted March 7, 2006 Share Posted March 7, 2006 I would check the brake pad wear indicators. Quote Link to comment Share on other sites More sharing options...
wallaceg Posted March 7, 2006 Author Share Posted March 7, 2006 I would check the brake pad wear indicators. What's the best way to do that on a Subaru(this is my first 'Roo)? Quote Link to comment Share on other sites More sharing options...
