April 9, 200620 yr first clean out your trunk or hatch area to make sure its nothing loose. Could be shocks, shot bushings, a bad exhaust pipe hanger, or that racoon you ran over last week nipper
April 9, 200620 yr first clean out your trunk or hatch area to make sure its nothing loose. Could be shocks, shot bushings, a bad exhaust pipe hanger, or that racoon you ran over last week nipper I thought a racoon went "squwash a quishy" :-\
April 9, 200620 yr I thought a racoon went "squwash a quishy" :-\ well if the bugger gets wound around the axle nipper
April 9, 200620 yr The only thing worse than your own road kill is running over someone elses! Seems like you are thunkin' right...shock it probably is. Kevin
April 9, 200620 yr If what ever car this is has a rear sway bar. Worn bushings in the links to the control arms can cause this noise
