April 22, 200620 yr I had a question, I searched, but all of the posts I came across only mentioned the 504 and 505 Puegeots. Does the 604 share the same wheel bolt pattern? Is the back spacing ok with these and an EA82?
April 22, 200620 yr i do not believe they are the same bolt pattern....could be wrong.....been known to happen.
April 22, 200620 yr I think only the 5 series... 504 and 505's have the 4x140mm bolt pattern. Any other peugeot wont bolt up -Brian
April 23, 200620 yr Author The guy selling them measured them and said that they are 5.5" across the hub. That sounds like it would fit. I wish I knew if some else has used them.
April 23, 200620 yr I had a question, I searched, but all of the posts I came across only mentioned the 504 and 505 Puegeots. Does the 604 share the same wheel bolt pattern? Is the back spacing ok with these and an EA82? Don't think I hav actually seen this question before. From what I can tell, the 604 wheels will fit the subaru. No mention of backspacing in anything I saw, but I am guessing it is ~+20 like the 505 wheels. Also, sounds like most of the 604s had the funky lugnut wheels. They had larger studs than the 505, so aftermarket lugnuts of some sort may be required.
