jaacina Posted April 22, 2006 Share Posted April 22, 2006 I had a question, I searched, but all of the posts I came across only mentioned the 504 and 505 Puegeots. Does the 604 share the same wheel bolt pattern? Is the back spacing ok with these and an EA82? Quote Link to comment Share on other sites More sharing options...
86ruguy Posted April 22, 2006 Share Posted April 22, 2006 i do not believe they are the same bolt pattern....could be wrong.....been known to happen. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted April 22, 2006 Share Posted April 22, 2006 I think only the 5 series... 504 and 505's have the 4x140mm bolt pattern. Any other peugeot wont bolt up -Brian Quote Link to comment Share on other sites More sharing options...
jaacina Posted April 23, 2006 Author Share Posted April 23, 2006 The guy selling them measured them and said that they are 5.5" across the hub. That sounds like it would fit. I wish I knew if some else has used them. Quote Link to comment Share on other sites More sharing options...
Turbone Posted April 23, 2006 Share Posted April 23, 2006 http://www.ultimatesubaru.org/80s/wheels2/peugeot-reference.jpg Quote Link to comment Share on other sites More sharing options...
calebz Posted April 23, 2006 Share Posted April 23, 2006 I had a question, I searched, but all of the posts I came across only mentioned the 504 and 505 Puegeots. Does the 604 share the same wheel bolt pattern? Is the back spacing ok with these and an EA82? Don't think I hav actually seen this question before. From what I can tell, the 604 wheels will fit the subaru. No mention of backspacing in anything I saw, but I am guessing it is ~+20 like the 505 wheels. Also, sounds like most of the 604s had the funky lugnut wheels. They had larger studs than the 505, so aftermarket lugnuts of some sort may be required. Quote Link to comment Share on other sites More sharing options...
