5speed dual range trannys
Not sure if this is in the right spot or not, but at the Olympia PAP next to the Olympia Air Feild, there are about 4-6 Subaru's that have 5speed dual range trannys. I have no idea if they are any good or not, but at least the INFO is on the board.
The Kid
Olympia, WA
So whats so great about the 5 speeds? I know they have slightly better low range. But the top gear would be useless in my Brat, it's 4th already goes faster then the tires are rated...
i went from a 4 spd to a 5spd and get a better top end.i am not so wound out going up hills ,get better acceleration.i have 27 inch tires and a weber which help as well.in my 4 spd i found that i was struggling to get to speed on the freeway .with the 5 spd i can accelerate even in 5th.i can maintain about 65 mph going up 6% grades in 4th at about 3500 rpms.huge bonus.
I'll have to drive my brothers 83 wagon more. See, I have a dual carb ea81, not just the carbs, but also the better flow heads. So maybe that makes my car powerful enough in 4t. Normally I can keep over 90km/h (about 55mph) on hilly roads. I thought in the 5sp boxes 1,2,3 gears were the same, fourth a little shorter, and fith fair bit above 4sp's fourth.
The biggest benefit is for people who have pushbutton (single range) 5 speeds. They pick up the low range, which really helps offroad.
The last time I bought a Subaru tranny at PaP, they tried to charge me extra for the "transfer case." I told them to go ahead and take if off, if they could.
