01 Legacy GT How are door panels removed?
I'd like to install better speakers. I need to know where all the clips, screws etc are located and the correct procedure, twist, push here, pull there, so I don't damage the door panels.
I've had my bad experiences (broken clips etc) with other cars. Unfortunately, I'm not familiar with the model year changes, so I don't know if instructions are already posted.
Thanks
Bob
PS What years have the same body style as my 2001 Legacy?
Subarus are giant legos, they dont change much Here is how it works in a 97/98. You should have 2 screws in the arm rest and one at the door release. Remove the trim panel behind the outside mirror inside the door, it pops off. Start at the bottom of the door with a long screwdriver. there is usually one button style clip in the corner, and work your way around. Pop one at a time. Everything is plastic so they are fairly robust. Lift the panel off the door. Disconnect all harnesses at this point. Installation is the reverse.
Hope that helps.
nipper
