Jeff1952 Posted June 12, 2006 Share Posted June 12, 2006 I have a 1985 1.8 engine. Strickly off road use. Do I need an engine control modual to run this? If so Where can I get a gerneric unit. The motor is stripped down. Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted June 12, 2006 Share Posted June 12, 2006 I think you'll need the little computer unit to talk to the carb, other than that I don't think you'll need too much computing. How are you planning to get fuel to the motor? Do you know what car the motor came out of? Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester Quote Link to comment Share on other sites More sharing options...
s'ko Posted June 12, 2006 Share Posted June 12, 2006 All engines will need a computer. The carbed one dont necessarily need one to "run" It may not be optimal w/o one. The fuel injected one will need a computer and a host of other sensors. What type of engine is it? EA81 or EA82. BW Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted June 12, 2006 Share Posted June 12, 2006 Most likely the answer to your question would be no you do not need any type of engine control on that engine.Most likely since you are running an ea81 or ea82 it is carbed and you can do away with most of that emission control crap.I used to live in soldotna,Ak and I did something similar on my brothers old sube.If you can it would be worth while to convert your stock carb over to a weber 32/36dgev.Lot less problems to face when you are in the middle of no where like any part of Alaska can be.Good luck. Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted June 12, 2006 Share Posted June 12, 2006 Oh ya, Welcome to the board! I know your secrets!!! You must share them with the group or face sanctions! Tell the rest of the Subie Folks what your up to??? Better yet, post some pics of the original proto types and build process of the current monster! We can all learn from your input. Way cool, Glenn 82 SubaruHummer--and I though this was cool... 84 GL Mad Max 01 Forester Quote Link to comment Share on other sites More sharing options...
fastenova Posted June 12, 2006 Share Posted June 12, 2006 If you put a different carb on there I think you can run without the computer. Someone can verify this, but I believe the Hitachi carbs interface with the ECU a bit since they're feedback carbs. I've got a weber on mine and things are strictly vacuum controlled (EGR, vac. advance, brake booster and HVAC are the only vac. lines I've got hooked up). The rest of the electrical is purely for sensors (coolant temp, oil pressure). Since ignition timing is controlled by the disty & vac. advance, is there anything the ECU does with the coil / ignition system that makes it necessary? Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted June 12, 2006 Share Posted June 12, 2006 a little bird told me... This was a 1985 GL vin JF2AN53B8FE464540 ---wagon 4X4, 5 speed, two speed transfercase, EA82, Carburated, in a previous life.... Quote Link to comment Share on other sites More sharing options...
Jeff1952 Posted June 13, 2006 Author Share Posted June 13, 2006 Most likely the answer to your question would be no you do not need any type of engine control on that engine.Most likely since you are running an ea81 or ea82 it is carbed and you can do away with most of that emission control crap.I used to live in soldotna,Ak and I did something similar on my brothers old sube.If you can it would be worth while to convert your stock carb over to a weber 32/36dgev.Lot less problems to face when you are in the middle of no where like any part of Alaska can be.Good luck. Where might a person find such a carb. Soldotna is on the top of the list for places to retire. Jeff Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted June 13, 2006 Share Posted June 13, 2006 They are getting rather hard to find,but you can find them on ebay.If you want get ahold of my brother Jason at riverside auto in soldotna and he might be able to locate you one.262-5851 anyone at that parts shop can help. Quote Link to comment Share on other sites More sharing options...
Jeff1952 Posted June 13, 2006 Author Share Posted June 13, 2006 This site is awesome!!!!!. Thanks for all the information Jeff: Quote Link to comment Share on other sites More sharing options...
()__1337_CRAYOLA__()> Posted June 13, 2006 Share Posted June 13, 2006 about the webber carb. would the webber on a pinto work with a soob? Quote Link to comment Share on other sites More sharing options...
