Help TroubleShooting Vibration
I'm not sure if this is in the right forum, because I'm not quite sure where my problem is coming from. My 93 Impreza has a horrendous vibration. It's noticeable at an idle, but it's at it's worst at speeds over 50. I've checked my tires, no signs of bulges or a bad tire. I'm thinking it's either bad motor mounts, or something else. Also, the vibration seems to stop and then start again by itself at highway speeds; and I can feel it mostly in my seat, more than in the steering wheel.
Help!
Help!
If its when the car is stoped, its not a tire. Maybe a fouled spark plug?
nipper
Ok lets start with basics, how many miles and which tranny. Does it do it cold or all the time. What happnes on turns. Is there any noise that goes along with this. When was the last time somone checked the wheel bearings and cv joints?
nipper
It has a rebuilt tranny with 50,000 on the rebuild, 1.8L, in all has 163,000 miles. Does it pretty much all the time, cold or warm.
Nothing wrong on turns and no noises. I checked on the joints and bearings on Saturday. Didnt find anything.
Your going to make this tough arent you. I dont know if imprezzas have a center carrier bearing on the driveshaft to the rear wheels. if it does check that. Also rotate the tires one at a time and see if the vibration moves
nipper
LOL, Im not trying to make it hard, I swear. Im still learning (taking auto classes in college). I know I need an alignment, but I'll also try the things you suggested.
So you dont think its worn motor mounts? It feels like the vibration isnt in any one side, it feels like its from the front and I can feel it more in my seat than my steering wheel.
Motormounts almost never go bad on a sooby. Rotate the tires. Shcek tierod ends and balljoints. Check the drivshaft.
What college are you going to?
nipper
Just Pima Community College. I just started 3 weeks ago. Im thinking of getting into Automotive Engerneering Technology. Dunno where though, but since Pima is only a 2 year college, I have time to decide on a 4 year.
WOHOO! I have an associates degree in automotive engineering technology from SUNY at Farmingdale. The program is ABET accredited, only one on the east coast. I ran out of money to go further in the feild, as automotive engineering schools are very pricey and few and far between.
I'm thinking of going back, have to see where my lawsuit from the major car aaccident goes.
nipper
I saw some schools in my search that were not just Auto specific for AET. Many state universities have the program I believe. The University of Arizona does I think, as well as one in Detroit
here on the east coast they are few and far between. i hate to date myself but when i was going to college (80's) detroit was the last place you wanted to be. There were also fewer schools.
So are you going into this cold, or always have played with engines?
nipper
Mostly going in cold. My dad always taught me simple things like to check fluids, tire pressure, identifying makes and models, etc. Most of what I have are book smarts and a huge love for cars and Subaru.
http://cgi.ebay.com/INTERNATIONAL-TEXTBOOK-16-AUTOMOTIVE-REPAIR-BOOKS-1940_W0QQitemZ4652916750QQihZ002QQcategoryZ378QQrdZ1QQcmdZViewItem
get something like this. It will give you good basics. Once cars got away from coal dust nothing really has changed. (if you dont want it ill bid on it. I have a great 1940's repair book that covers everything, and you can see the evolution of the modern automobile.
The only thing that has changed is the way they manage things. Next HUGE change is direct injection of gasoline and electronic valave actuation
Thanks for the suggestion, but Im flat broke right now. Maybe when I get some cash Ill look for those again
ill snag them then see what we can work out
nipper
before i went back an reread your post,i was gonna mention wheel-bearings.but seeing that it happens while not in motion...Hmm,never been good at troubleshooting :-\
what about that dogbone looking bar that attaches to the top backside of the engine.i think it's called a pitch wedge (or something like it)
when did it have its last full tuneup? And timinbelt
nipper
Check your spark plug wires, sounds like you are running on 3 cylinders.
one of my guesses, plugs or wires, and shcek codes.
nipper
Plugs and wires are fine guys, I told you I checked them. I'm going to try a rotation and wheel balancing.
If it happens while at idle and not moving, it has nothing to do with the wheels, bearings or driveshaft.
Nipper was right that the motor mounts are fairly strong, but if the engine wasn't supported properly when your transmission was removed, there's a good chance they were ripped at that point.
With the car on ramps, get underneath and inspect the two mounts between the engine and front crossmember. If you can use a jack to push up on the oil pan while your inspecting them. DON'T lift the car using the oil pan, just put some pressure on it to raise the engine a bit.
What about a loose or damaged front pulley/sprocket? (22mm bolt)
Mine wobbled enough to shred the alternator belt and ruined the keyway where it mounts to the crankshaft.
I was going to say it kinda sounds like it is not firing on one cylinder.. or firing out of order. It could also be a radiator fan going south.. I have had radiator fans that shook the living hell out my cars. If you would like me to take a look at it and see if we can narrow it down a little bit, I don't mind.
( elijafir@cox.net )
-Eli-
