November 2, 200322 yr Had something weird happen yesterday. Was on the freeway and had a pretty nasty vibration come on when I left off the accelerator. It almost felt/heard like something was clanking. When I accelerated again, it went away. It seemed to go away, because it doesn't seem to do it....however I haven't really gone on the freeway again.... Only thing I can think of is cv axle or diff/trans. The axles were rebuilt in 97......they should've been replaced......they have been making clicking under acceleration......I think they've just come to the point where all the inards are toast. Any ideas/comments?
November 2, 200322 yr Maybe your auto-trans is getting tired? Do you work it hard?? Doesn't sound like a driveshaft problem, for which I would expect a clonking on low speed tight turn manouvres, and only a single clonk at throttle on or off. It COULD be a badly balanced driveshaft, and during deceleration you hit a spot where it was able to resonate. I hate these kinds of intermittent problems, you replace something and think everything is fine 'cause you can't provoke the problem back. Then, like two days later ....clonk..drone...splutter!
November 2, 200322 yr How about a bad engine mount on the [right side???] non-torque drive side? Deceleration torque could cause the engine to vibrate, would be more apparent at highway speeds. Can you reproduce it by revving up in a lower gear and releasing the gas at a slower speed?
November 2, 200322 yr You didn't qualify the way it felt, but I'd also suggest looking at motor/tranny mounts as well as steering/suspension linkage. Are your tires wearing evenly? Put it up and check the wheels,hubs, tie rods.etc.
November 3, 200322 yr Author It's very possible the auto trans is getting tired.....and yah I probably am a little harder on things then most. I mentioned cv axles because they were rebuilt, and really should have been replaced. They did click after being rebuilt and within the past months I do get clicking under acceleration and turning. It still however may not be the cause of the problem, just an additional one. It really felt/sounded like something was hitting/banging. As for driveshaft.....I don't have one, FWD. Just replaced engine mounts with sti engine mounts 2 weekends ago. It did do it at slower speeds, but was no way near as bad, and after I stopped and looked at the car and everything, I couldn't reproduce it. It is definitely speed dependant, not engine rpm dependant. It felt like a vibration (out of balance tire) as well as the noise I mentioned earlier. As mentioned I have new engine mounts, tranny mount looks fine, I have a new one I will be putting in shortly, but I don't think that is the cause. Steering rack bushings just got replaced last weekend with the whiteline poly bushings. Tires are wearing fine. I've jacked up the front and rear of the car and everything seems fine, nothing loose. Draining fluid in the diff and trans are about the only way I can think to check them.
November 3, 200322 yr Very puzzling that something that dramatic can't be easily located. Just a wag - maybe loose axle nut? let us know.
November 3, 200322 yr Author I am still thinking it's the axles. Only thing else I can think of is trans or diff, and axles are much cheaper then trans or diff. I did not check the axle nut, but I tried shaking the wheel, and it was not loose.
November 3, 200322 yr Okay, my bad. I know your car is FWD, but I meant that one of the axles could be out of balance. Terminology is so hard to get right! I would have said "propshaft"
November 3, 200322 yr Author Actually the term axle would be correct Yeah it's possible one of them is out of balance. I just don't know why it would do it, then go away, and now not do it any more. I'll be driving up to the airport tomorrow, so I'll see if it does it again.
November 3, 200322 yr Josh! In my own private world of automotive terms: Driveshaft/half-shafts provide drive from a diff to a wheel. A propshaft provides drive between diffs, or engine and a diff. Axle is anything cylindrical that might rotate or facilitate the rotation of something mounted to it
November 4, 200322 yr Author checked all the tires....they all good. I couldn't reproduce the vibration today. I'll see what i can do when I go to the airport tomorrow morning. Emil, just difference in terms
November 4, 200322 yr Something got temporarily caught up on a half-shaft... and then came off again? I'd think you'd feel that more or less constantly though, instead of just on decel. Just trying to add to the thought process. Commuter
November 4, 200322 yr Did you feel it in the steering wheel? Did it seem 'up and down' side to side' - anyqualifiers might help. Any pulling/drifting off track? The noise - was it high pitched and tinny of low pitched and knocy/clunky (usually the low pitched noises are trouble). We need some hypnotic regression to bring your suppressed memory to the surface.....you're getting sleepy...sslleeeeeeeppyyyyyy.............
November 4, 200322 yr I have seen/heard/felt inner axle joints(DOJ) produce the above mentioned problems.. something to consider
November 4, 200322 yr Author It was more like a clunking noise. I drove to the airport this morning, and didn't have any problems. I'm going to order axles and replace them.....they're probably due anyway.....I'll probably get to replace the ball joints as well.
November 4, 200322 yr this test. Open your hood while the engine is running and stand on the brakes while slowly revving up the engine in drive and then try it in reverse. A bad mount would let the engine torque up off the seated position. I've done this with a V-8 and watched it look as if it would jump out of the engine compartment because the mount was totally broken in half!
November 4, 200322 yr Author what do you mean? sure money is an object, but I can get reman'd axles for 55 a piece. Ball joints shouldn't be too much.
November 5, 200322 yr Author I'll try the brake and accel thing. Like I said I don't think it's mounts......since I just replaced them, but it might show me something else too.
