August 25, 200619 yr One of my vehicles is a Suzuki Samurai. The engine is going to need replacement soon. Since I am a Subaru fan, I was thinking about a 4 or 6 cyl in the Suzuki. Perhaps a 4 will be fine. Anybody tried it ??? I am really interested. jaime:)
August 25, 200619 yr One of my vehicles is a Suzuki Samurai. The engine is going to need replacement soon. Since I am a Subaru fan, I was thinking about a 4 or 6 cyl in the Suzuki. Perhaps a 4 will be fine. Anybody tried it ??? I am really interested. jaime:) I have a Samurai also and thought about this at one time. I know you'd have trouble trying to fit an opposing cyl. engine between the frame rails. I thought about an EA81 or EA82, took a few measurements and abandoned the idea. The valve covers would stick through the fender wells.
August 25, 200619 yr I'll bet a Justy engine could work. Not sure if that would be an upgrade though.:-\
September 2, 200619 yr what about in the back??????? i really dont know the layout of the 'zuk that well, but i know the vehicle abstractly, and from the outside, very VERY well... but would it be possible to cram it over the rear axle? also, you might consider an older, OHV ea-81 engine because of the shorter height... would that fit where the OHC motors wouldnt? just a couple thoughts. i like that idea :- )
November 4, 200718 yr Realise this is a very old post.... but anyone done this yet? Tempted to give it a go - measured up an ea81 quickly and looks like it will just fit - my samy has a body lift so the engine could sit over the chassis rails... Would have to tilt the engine up to do the valve clearances tho!
November 5, 200718 yr Stick a ER27 in the back facing backwards, flip the axles to reverse drive... Would be fun.
November 6, 200718 yr Stick a ER27 in the back facing backwards, flip the axles to reverse drive... Would be fun. They already lack weight in the front for hill climbs - would be hopeless off road like this.... unless you added some ballast up front...
November 6, 200718 yr Good point. I thought about that after posting what I did... Would do what lifted Yotas (Hilux, as known here in Aus, we call them Rollux's) do I guess..
November 7, 200718 yr I forget who but someone one here was building a Hatch with a Zuki frame and suspension under it. If I remember right he was going to keep the Subie engine and again if memory serves me right (uh oh), I think it was Bratus1.
November 7, 200718 yr Yup, it was bratsrus1 (Jerry). IIRC, he told me he's going to run an EJ22 with a 5-speed d/r into a divorced t-case. When it's all done, its gonna be sick!
May 19, 201015 yr serious resurrection ... On the old board there was a guy with an ea81 and dual range mounted in the rails of a sammy - don't know if his project ever got finished but he had at least one blurry pic up.
May 21, 201015 yr It would be a neet project to run the Toyota W series driveline in a Samuri frame with the Sub engine kindofa oriental hot rod .;o)
