guidop70 Posted September 16, 2006 Share Posted September 16, 2006 Reddish Wagon with 4WD, AC, Auto Windoows, door locks & side mirrors AM-FM with Tape Player, tilt wheel, 4 new tires. All accessories in full working order. includes never-used tire snow chains. Paint has minor blemishes and some pine cone depressions, but when washed the paint just shines like almost new ( A factory applied coating of ??) There is some wind noise and rattling on a bumpy road. The interior is essentially clean and intact. It's in pretty nice shape for 118 K miles and is going to be for sale soon in the California's SF Bay Area So what are the questions and answers? Guido70 Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 16, 2006 Share Posted September 16, 2006 So what are the questions and answers? So far sounds normal. I paid $1K for an 87 with NO rust last year. (in CT) I'd rather replace the driveline than do body work. Some things to look at / check / fix: Timing belts Cooling system hoses CVJ boots Radiator fins Quote Link to comment Share on other sites More sharing options...
guidop70 Posted September 17, 2006 Author Share Posted September 17, 2006 ] So far sounds normal. I paid $1K for an 87 with NO rust last year. (in CT) I'd rather replace the driveline than do body work. Some things to look at / check / fix: Timing belts Cooling system hoses CVJ boots Radiator fins Dave, Thanks for your input. Why did you make your comment re: the driveline than do body work? As I don't recall mentioning those items. I thought I had a water pump leak, but all of a sudden it stopped! But I don't know if it will start again. A good source ( A mechanic) said he used Bars Liquid and it stopped his leak for 6 months. Even so. with the 118K miles a timing belt (2) are due. The quotes around here all run about $700, which includes the whole shabang, due to the cost of labor just to go in again if it's not fixed completely the first time. I've had the boots replaced several times - too bad they weren't made better to begin with. I also had a clutch replaced at about - I guess - 60K which is another concern. But I guess that's the situation with an old buggy, but it's a great car - visibility, lots of space, 4WD for skiing ( no chains!!!!), but under powered, but with patience it gets you there with good mileage. I f you have any other comments 0 shoot them to me Thanks, guidop70 PS Yes, I have no rust too Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted September 17, 2006 Share Posted September 17, 2006 I'm confused.. are you looking at one to buy.. or are you trying to sell this one and asking us what we think it may be worth? Quote Link to comment Share on other sites More sharing options...
Durania Posted September 17, 2006 Share Posted September 17, 2006 Dave was referring to the simplicity of replacing the driveline than that of doing body work and I agree with him completely. Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 18, 2006 Share Posted September 18, 2006 ]Why did you make your comment re: the driveline than do body work? Durania717 got it right. It was a partial explanation of the high price for a 19 year old car in CT. I don't like the idea of the additive leak fix. But I am assuming that I am going to be using a car for a long time. Also, all you need is a few minutes with less than full coolant, and you're looking at headgaskets or worse. Quote Link to comment Share on other sites More sharing options...
wesley willis Posted September 18, 2006 Share Posted September 18, 2006 paid 1200 canadian for a 90 loyale that's been COMPLETELY redone. new paint, trans, motor, radiator, axles, diff, all shocks/struts. the only thing it didnt have were good brakes which cost me a small fortune to finally get working right again. Quote Link to comment Share on other sites More sharing options...
