September 18, 200619 yr Author Ok, got the parts spent $345CDN bought belts, pulley, and the piece it grabs onto behind it, i was told to torque it downt to 150ft-lbs!!!!!! THis has happened more than once, and my dad seems pissed after spending so much money on this car, i mean we must have spent 15,000 between repairs, and wear and tear, and oil changes, but all this money was spent after it was more than 12 years old. Oh well, i will never get back that money. But im hoping that i get this car blessed and nothing goes wrong. Im sick off shady mechanics, they dont know what they are doing. YOu might think it saves u money, but it deosnt, they cost u money in the long run. Subaru Missasauga is the only people who touch my subaru till i die.
September 19, 200619 yr Author Ok ,new update, i pulled out the old key from the crankcase, but dam, i dropped the other one in the timing cover:mad::mad::mad:. SO now i gota remove the timing cover. Oh well, but it seems like a simple job, and i bought a torque wrench set with impact pieces(the black hard steel ones) and i will torque the bolts down to 150ft-lb. Am ill dumb some blue locktite on the bolt, that odd to hold it eh? And i bought this thing that will hold the pulley instead off jaming the flywheel($20). So tommorow hopefully it wont rain so i get get a better look at things. In total i have spent about $500CDN between tools($150) and the rest in parts (key, pulley, belts, advice).
September 19, 200619 yr I replaced my harmonic balancer, the 2.2 is 80 lbs. torque. I did not use thread lock. I used a thin coating of engine oil on the bolt.
September 19, 200619 yr Ok ,new update, i pulled out the old key from the crankcase, but dam, i dropped the other one in the timing cover:mad::mad::mad:. SO now i gota remove the timing cover. Oh well, but it seems like a simple job, and i bought a torque wrench set with impact pieces(the black hard steel ones) and i will torque the bolts down to 150ft-lb. Am ill dumb some blue locktite on the bolt, that odd to hold it eh? And i bought this thing that will hold the pulley instead off jaming the flywheel($20). So tommorow hopefully it wont rain so i get get a better look at things. In total i have spent about $500CDN between tools($150) and the rest in parts (key, pulley, belts, advice). 150 is too high, you can strip the threads in the crank, then you will be really in trouble. Go with the numbers we said here. With the Loctite (which i dont beleive in personally there) and the proper torque, you wont have a problem. Remeber that this may have to be removed again in the future, and you donw want to stretsh any threads. nipper
September 19, 200619 yr nipper is correct, you should use a torque wrench, but i never do. i do guarantee i'm getting well past the recommended value. Isn't a calibrated arm great? i have one of those too (its called many years of pulling a wrench) nipper
September 19, 200619 yr Author please post a pic of the "thing that holds the pulley" This thing it has a handle and a rubber belt rated a 1300lb. and it put it around the pulley.
September 19, 200619 yr This thing it has a handle and a rubber belt rated a 1300lb. and it put it around the pulley. Ah yes the ol' pully holder thingy , otherwise known as a strap wrench. nipper
September 19, 200619 yr Author Ah yes the ol' pully holder thingy , otherwise known as a strap wrench. nipper So, which this i dont need to jam the flywheel correct? And about this ft-lb for the bolt, im totally lost. I mean the dealer saus 150, u say 70-80 my dad thinks 150, someone says 100, somone says its to much aw!!!
September 19, 200619 yr So, which this i dont need to jam the flywheel correct? And about this ft-lb for the bolt, im totally lost. I mean the dealer saus 150, u say 70-80 my dad thinks 150, someone says 100, somone says its to much aw!!! Haynes Manual (which information comes from the factory service manual) Crankshaft Pully Bolt 2.2L 70-80 Ft Lbs 2.5L 90-100 Ft Lbs With the loctite you will be fine. mipper
September 19, 200619 yr Haynes Manual (which information comes from the factory service manual) Crankshaft Pully Bolt 2.2L 70-80 Ft Lbs 2.5L 90-100 Ft Lbs With the loctite you will be fine. mipper 99 legacy FSM says 90-100lbs for 2.2 Don't have one for other years.
September 19, 200619 yr 99 legacy FSM says 90-100lbs for 2.2 Don't have one for other years. lets call it 100 ft/lbs across the board. i dont want to confuse him any more :cool: nipper
September 19, 200619 yr Author lets call it 100 ft/lbs across the board. i dont want to confuse him any more :cool: nipper lol, well my dad said it was 140ft-lb, told by subaru. So i dont know trust the manual ,or professional.
September 19, 200619 yr lol, well my dad said it was 140ft-lb, told by subaru. So i dont know trust the manual ,or professional. manual when it comes to torque specs. 140 is 40-50% over spec, and thats huge. nipper
September 19, 200619 yr manual when it comes to torque specs. 140 is 40-50% over spec, and thats huge. nipper Make that a 100% http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg
September 19, 200619 yr Make that a 100% http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/Timing_belt8.jpg And here i was trying to play peace maker ... but your going to make him convert n/m to ft lbs, you bad.... nipper
September 19, 200619 yr ... but your going to make him convert n/m to ft lbs, you bad.... nipper Nah, ft-lbs are there inside the brackets....
September 19, 200619 yr Please remember that over torque on a bolt can stretch the threads and also cause it to be weaker. I also beleive the manuals are correct but I torque to a 100 ft. lbs because so many people her disagree with the lower torque figure.
September 20, 200619 yr Author IM back guys, and i did it 140ft-lbs with blue locktight, changed the key,and the pulley and belts, runs perfect. NOW my alternator died :horse::horse::horse:. So dum o well, new alertornator on the way. What do u guys suggest i do, rebuild it? New oem one? another good name aftermarket you can suggest? and this alternator was replaced once about 6 years ago. So ya. but i didnt even add another 100,000km since the last time it was changed why did it die so early? if i accidentally sprayed something on it or water got on it, would it die? And just wondering, a torque wrench is suppost to release once it reaches 140ft-lbs correct? like it just lets go? because i dont want to think the screw is stripped:o. Ok well i drove it with a dead battery and everything is great, dum alternator though. Oh well. After the alternator is fixed i better not spent another dime!!!!! or i will totally dump this car!!
September 20, 200619 yr You put the bolt on to tight. HAHAHAHAHA now was it left hand rule and right hand threads or the other way around Did you overtighten the drive belts? Just go anyplace reputable for a rebuild. nipper
September 20, 200619 yr Author HAHAHAHAHA now was it left hand rule and right hand threads or the other way around Did you overtighten the drive belts? Just go anyplace reputable for a rebuild. nipper Nope not to tight not to loose, i can still push the belt a tiny bit. So is that reputible? or does it need to be more tight maybe? is it slipping possibly?
