tgzeagles Posted September 30, 2006 Share Posted September 30, 2006 I've looked in several locations (including here) and can't find the definition of error #8. Can anyone point me to a comprehensive list of errors for this vehicle? Or, simply what error 8 is? Thanks as always. Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 30, 2006 Share Posted September 30, 2006 Are you sure its a 8? Usually the first long blink is a 10. Quote Link to comment Share on other sites More sharing options...
Sister7 Posted September 30, 2006 Share Posted September 30, 2006 Single digit codes are model specification. According to my 88 FSM, 08 for a SPFI means California model w/ AT. Quote Link to comment Share on other sites More sharing options...
tgzeagles Posted September 30, 2006 Author Share Posted September 30, 2006 Single digit codes are model specification. According to my 88 FSM, 08 for a SPFI means California model w/ AT. Well, that's what I have a 1987 CA wagon w/AT. How do I get past this to the error that's causing the CL to be on. I watched it blink 8 short times for a while (~10 minutes). Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 30, 2006 Share Posted September 30, 2006 http://www.ultimatesubaru.org/forum/showthread.php?t=49918 This is the link for the codes. Do you have the 3spd AT or the 4EAT? Quote Link to comment Share on other sites More sharing options...
tgzeagles Posted October 4, 2006 Author Share Posted October 4, 2006 http://www.ultimatesubaru.org/forum/showthread.php?t=49918This is the link for the codes. Do you have the 3spd AT or the 4EAT? Thanks for the link, I have the 3 speed AT. Quote Link to comment Share on other sites More sharing options...
Cougar Posted October 4, 2006 Share Posted October 4, 2006 If you have no error codes and the CEL is still on, the problem may be internally with the ECU. The light driver circuit may be bad. I have repaired those in the past with a new IC. The circuit is basically a transistor switch to ground. Quote Link to comment Share on other sites More sharing options...
