hancho3 Posted October 1, 2006 Share Posted October 1, 2006 I am starting to look for a new tranny for my brat, was wondering what models I can look for that will have the same tranny. Mine is in a '81 Brat EA81 with a 4Spd D/R. Any info appreciated thanks, -Kurt Quote Link to comment Share on other sites More sharing options...
Sister7 Posted October 1, 2006 Share Posted October 1, 2006 Any brat or hatchback, and GL wagons from '80 to '84. Quote Link to comment Share on other sites More sharing options...
Qman Posted October 1, 2006 Share Posted October 1, 2006 That is true for the D/R. However, I am not sure that the '81 is the same as the rest. The linkage should be different but I am not positive as I never took the trans out of my '81. Quote Link to comment Share on other sites More sharing options...
Qman Posted October 1, 2006 Share Posted October 1, 2006 Call Aarons in Seattle. Tom or Brian should know if they interchange. 206.243.4665 Quote Link to comment Share on other sites More sharing options...
MoscowSubaruDude Posted October 1, 2006 Share Posted October 1, 2006 Would the 4sp D/R out of an 83 wagon work? I've got my junker parts wagon, I can pull it outta there and we'll see about getting it to ya... I have to head over to Oly in a week or three anyway, wouldn't be too much trouble just to bring it over. Lemme know if A) it will work and if you want it. It shifts well, all synchro's intact, not too much linkage slop. Decent tranny. Quote Link to comment Share on other sites More sharing options...
GLCraig Posted October 1, 2006 Share Posted October 1, 2006 The 81 brat transmission has a different casting for the transfercase and the rear output is a little different too. If you want to swap parts between the 81 brat trans with a gen2 D/R, that can be done. It may also be possible to just make a Gen2 D/R work in a Gen1 Chassis. Quote Link to comment Share on other sites More sharing options...
MoscowSubaruDude Posted October 1, 2006 Share Posted October 1, 2006 How different? aka... will it bolt up? Or does it require some mods? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 1, 2006 Share Posted October 1, 2006 I put an 81 GL Brat trans into a Gen 2 Brat (82) and it fit like stock. I just had to turn the 4WD linkage 90 degrees.... you'll see when you look at it. It's threaded, and turns easily. No problems with mounting. 81/82 have a different 3rd and 4th gear. They are lower than the 83/84 4 speed. GD Quote Link to comment Share on other sites More sharing options...
