puritan Posted October 19, 2006 Share Posted October 19, 2006 Hello fellow enthusiasts, my problem is a delay before transmission engages after shifting into drive, it's fine in reverse, any advice will be much appreciated. The problem is worse after ATF is warmed up (around 10 seconds before engangement). Once the tranny engages it drives fine. I have changed the fluid and filter which seemed to improve it slightly but doesn't sort the problem. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 19, 2006 Share Posted October 19, 2006 Other posts have indicated around this year some kind of issue with a pump seal preventing rapid build up of pressure resulting in delayed engagement but I don't know if it applies to your vehicle. Quote Link to comment Share on other sites More sharing options...
puritan Posted October 19, 2006 Author Share Posted October 19, 2006 Other posts have indicated around this year some kind of issue with a pump seal preventing rapid build up of pressure resulting in delayed engagement but I don't know if it applies to your vehicle. Thanks for reply, if it was a pump seal would it not show the same symptoms when shifted to reverse? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 19, 2006 Share Posted October 19, 2006 i drove one of my old school subaru's for a long time with that symptom. it never got worse or caused any issues. i didn't know much about it at the time except the car drove fine. that pause before going anywhere was odd though. Quote Link to comment Share on other sites More sharing options...
nipper Posted October 27, 2006 Share Posted October 27, 2006 Thanks for reply, if it was a pump seal would it not show the same symptoms when shifted to reverse? eventually. If it takes more then one second to engage you have a tired front pump and seal. 2nd gear which is used for reverse doesnt need as much volume of oil to engage, so it will not be as bad. How long to go from reverse to drive nipper Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 27, 2006 Share Posted October 27, 2006 If that pump seal is faulty and the only symptom is delayed engagement, are there any risks to driving it like that if you're patient and wait for it to engage? Like is the pump not going to make enough pressure potentially and start allowing slippage? Quote Link to comment Share on other sites More sharing options...
puritan Posted October 31, 2006 Author Share Posted October 31, 2006 eventually. If it takes more then one second to engage you have a tired front pump and seal. 2nd gear which is used for reverse doesnt need as much volume of oil to engage, so it will not be as bad. How long to go from reverse to drive nipper Thanks for your comments, the box is off the car now so can't time the delay now. The box is half stripped and I have checked the valve assembly but can't see anything wrong there, was moving on to the pump next. Any idea where I can get seals and gaskets from? Please keep an eye on this thread as you seem quite knowledgeable. Quote Link to comment Share on other sites More sharing options...
puritan Posted October 31, 2006 Author Share Posted October 31, 2006 Thanks for your comments, the box is off the car now so can't time the delay now. The box is half stripped and I have checked the valve assembly but can't see anything wrong there, was moving on to the pump next. Any idea where I can get seals and gaskets from? Please keep an eye on this thread as you seem quite knowledgeable. How can I tell if the torque converter is ok? Quote Link to comment Share on other sites More sharing options...
nipper Posted October 31, 2006 Share Posted October 31, 2006 Thanks for your comments, the box is off the car now so can't time the delay now. The box is half stripped and I have checked the valve assembly but can't see anything wrong there, was moving on to the pump next. Any idea where I can get seals and gaskets from? Please keep an eye on this thread as you seem quite knowledgeable. Er....... um .... boy i dont pay attention to this board for a day and someone gets into all sorts of mischief. I think this is the first i've seen somone pull a slushbox apart. i hope your keeping really really good track of things. An autobox is not for the timid to pull apart. There are rebuild kits that you can get, but usually one tries to secure the kit first when doing it themselves. There were a few steps that were skipped here, like a proer diagnostics. If we could time the delay, we could have gotten a better idea where the problems was, along with a few other diagnostic steps. The pump has to be measured with a feeler gauge for wear, and i dont know what the specs are. You really cant always tell things by looking at them, you need more diagnostics to know where to look. Its possible that you may still have the problem or worse, since this seems a little extreeme, nipper Quote Link to comment Share on other sites More sharing options...
nipper Posted October 31, 2006 Share Posted October 31, 2006 How can I tell if the torque converter is ok? Cant now since you didnt let us tell you how to test it. Gut feeling there is nothing wrong with the torque converter. nipper Quote Link to comment Share on other sites More sharing options...
puritan Posted October 31, 2006 Author Share Posted October 31, 2006 Cant now since you didnt let us tell you how to test it. Gut feeling there is nothing wrong with the torque converter. nipper Thanks Nipper, I've always been adventurous and meticulous too so I thought in for a penny in for a pound, as I'm retired I have the time anyway. Quote Link to comment Share on other sites More sharing options...
nipper Posted October 31, 2006 Share Posted October 31, 2006 OOOOOOOOOoooooooooooooooooooooooo one of THOSE.... *hides the hand tools* nipper Quote Link to comment Share on other sites More sharing options...
puritan Posted October 31, 2006 Author Share Posted October 31, 2006 OOOOOOOOOooooooooooooooooooooooooone of THOSE.... *hides the hand tools* nipper No not that bad lol Quote Link to comment Share on other sites More sharing options...
