Purge solenoid INSANITY!
I agree. The 33 ohms may be too low and the system will show a fault for that also. Try removing one of the resistors so the resistance will be 50 ohms and maybe that will solve this trouble.
  • Replies 58
  • Views 7.5k
  • Created
  • Last Reply
Top Posters In This Topic
ok, cut out one of the resistors, so I now have 50ohms. Still doesn't work :(
Time to dig into the wiring to the ECU I think.
Thanks for all the help,
-Dave
...I have 40ohms in place of my EGR solenoid, and still have a CEL :mad: I think it's something inside the ECU causing the error.
by CEL you´re Meanin´ "Check Engine Light", isn´t it? ... I Wonder if the "ECS" Light permanently On, on my EA82 is the same CEL... ´cos I Didn´t Saw any "Check Engine" Light on my Subies´ Dashes... or they got Burnt Bulbs? :confused:
CEL is for fuel injection. ECS is for carb.
Really? Why did both of my '86s have ECS lights... and they're SPFI :confused:
86 was a weird year - that was the introduction year of the SPFI (only on 2WD's). After they did away with carbs they changed it to "Check Engine".
-Dave
One last thing to check is the ground lead for the unit. Check the voltage across it and a known good ground. If there is no voltage drop then the ground connection is ok and it would appear the the trouble is internally in the ECU.
