December 22, 200619 yr ok so u guys know how i had that "vacuum leak?" well i removed the carb and sealed up that bolt that came out of the intake manifold and sealed the carb up and put it on again tonite and i must not of hooked something up rite cuz now the damn thing doenst even run. i am at wits end now and it almost seems that im missing a hose on the top rear of the carb. i cant remember if there if there was something up with that or what but i can tell u guys i am pissed. i also got some smoke come out from the bottom passenger side of the engine compartment.........HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
December 22, 200619 yr Author im afraid not....im parked in a carport and there is barely any light to get a shot. im out there with a really big flash light
December 22, 200619 yr smoke from that area is usually just stuff burning on ur cat..if ur working on the engine debris can fall ontop and then it just burns and smokes for a while. just a suggestion, its not necessarily the problem, just had to put it out there.
December 23, 200619 yr Just a thought for the next time you pull a carb, mark the hoses and their barbs numerically, so when you put it back on, you know right where everything goes. Can't help you otherwise.
December 23, 200619 yr Author yes i probably should have marked the hoses....i drive it all the time it just idles like crap....i think i just have a $h*tty carb. oh and i dont have a cat on my exaust....ignore the smoking it has left im worried about the carb
