January 27, 200719 yr I do believe I found Rockys Electrical Demon...who I lovingly named Fred...could this be the cause of my red glowing dash lights and occasional charge issue??? I think this connector is toast yes??
January 27, 200719 yr Author Thanks..I thought so..Waiting to hear back from someone who has some...May the excorcism begin!! Bye Bye fred..I will miss you!
January 27, 200719 yr I hate to tell you this but.........Fred has relatives:-\ Start checking all the plugs that go to sensors, its a common point of corrosion on the XT6's, especially around the coolant areas.
January 28, 200719 yr I do believe I found Rockys Electrical Demon...who I lovingly named Fred...could this be the cause of my red glowing dash lights and occasional charge issue??? I think this connector is toast yes?? thse are the exact symptoms that the death shows when that connector comes undone, also while your redoing connections fix the cts plug those always rot and they kill performance and fuel economy
January 28, 200719 yr looks just like the alternator plug on my '88 before richie got me a replacement... not sure how it ever worked like that... I'm still hunting electrical daemons... it's been taking up the garage for months... --Spiffy
January 28, 200719 yr I'll get you a better one; you just need to butt splice it in or solder and insulate. I'm going to PAP tomorrow so I should be able to find one for you.
January 28, 200719 yr Author I'll get you a better one; you just need to butt splice it in or solder and insulate. I'm going to PAP tomorrow so I should be able to find one for you. Thanks ..I got it covered thoughBenebob has some and is sending one out..Thanks so much for the offer:)
January 28, 200719 yr Thanks ..I got it covered thoughBenebob has some and is sending one out..Thanks so much for the offer:)OK; glad it's covered. Regards and Happy New Year!
