February 6, 200719 yr Hi. I'm the proud owner of a 2003 Subaru Legacy Sedan, over 95k and running like a charm. I absolutely love my Legacy. However, in recent days the weather has gotten colder and generally more winter-like in my region...which is how it's supposed to be. My Subi's developed a rather dry sounding squeak in the front end that happens mainly when the front coil springs compress rapidly. At least, that's what it seems like. I called my local Subaru shop, and the man who sold me the car told me to monitor it - it's probably just ice in the wheel wells. It doesn't seem to be affecting the handling, so I am inclined to agree with him. And, I know that it is winter, we did just have a couple of small storms...so more likely than not that ice and sludge building up in the wheel wells has been the cause of the problem. But my question is, does this sound accurate? Or should I just take it right to the shop, right away?
February 6, 200719 yr I have never had this problem. I would try and clean that area out and see if the sound goes away. Perhaps even spray/grease some lube in there to see if that take of it. If it does not, maybe the problem is bigger. IMHO.
February 6, 200719 yr It may be something you have to live with. Winter makes cars squeek sometimes. The fix may not cure the problem. I would inspect the bushings and struts. It is probably a tired strut dust seal. Does it go away after the suspension warms up? it may not since in single difgits suspension doesnt really warm up much, it just gets more flexable (like us). nipper
February 6, 200719 yr Author It may be something you have to live with. Winter makes cars squeek sometimes. The fix may not cure the problem. I would inspect the bushings and struts. It is probably a tired strut dust seal. Does it go away after the suspension warms up? it may not since in single difgits suspension doesnt really warm up much, it just gets more flexable (like us). nipper No, although you're right; the suspension hasn't had much chance to warm up these days. My mechanic says that there have been lots of people in with the same complaint since we had our first snowstorm last week, and letting the cars sit and thaw in the heated bay has been helpful as all of the accumulated wheel well ice and sludge gets a chance to dissipate. I suspected instantly a worn bushing, but as I listened to the noise more and thought about the notorious wheel well sludge problem it did sound more like an ice-related sound... See, I just bought this car a little over a week ago and even though the roads I drive are rough, I didn't think they were rough enough to give the suspension a run for its money within the space of a week........
February 6, 200719 yr Author I have never had this problem. I would try and clean that area out and see if the sound goes away. Perhaps even spray/grease some lube in there to see if that take of it. If it does not, maybe the problem is bigger. IMHO. I may take her to the garage this weekend and get her in the heated bay. It is not going to be above freezing for many moons in these parts, so cleaning that caked-on and frozen road sludge from the wheel wells may prove to be impossible if I attempt it on my own. If the cleaning does not eliminate the problem, then it is time for plan two...taking her in and actually getting her checked out.
February 7, 200719 yr So is there a fix for tired dust seals? My 2000 Legacy with similar 95K+/- mileage has developed the squeaking the rear going over bumps. Is it possible to lube and replace dust seals? It may be something you have to live with. Winter makes cars squeek sometimes. The fix may not cure the problem. I would inspect the bushings and struts. It is probably a tired strut dust seal. Does it go away after the suspension warms up? it may not since in single difgits suspension doesnt really warm up much, it just gets more flexable (like us). nipper
February 7, 200719 yr So is there a fix for tired dust seals? My 2000 Legacy with similar 95K+/- mileage has developed the squeaking the rear going over bumps. Is it possible to lube and replace dust seals? usually some spray silicon will quiet them for a while. nipper
February 7, 200719 yr Thanks. I guess I'll crawl out there and give it a shot when it warms up to the point that my head doesn't crack going outside. Brrrrr. usually some spray silicon will quiet them for a while. nipper
February 7, 200719 yr What i do in the winter to prevent the squeaks is go get a car wash, seems to clear out all the salt, actually i haven't noticed any actually, but if u think its snow related, a car wash is a good idea, every few weeks.
