jon38iowa Posted February 14, 2007 Share Posted February 14, 2007 All was well with my Forester until tonight. I went to start it cold- Zero here but block heater plugged in, and after a couple click sounds, nothing.I mean the lights went out! I wiggled the battery cable and pop, the security lights(parking lights) come on blinking. So I try again, same scenerio, eveything is dead. Again until my hands began to freeze I wiggle the clean battery cables(tight as a drumm) and same as before, all lights shine brightly, but after atempting to start, dead again. Anyone have any thoughts? My guess is loose wire somewhere, but I would be happy to have others opinion. Last fall I put in a brand new Top of the line Napa battery, and I have been given no indication of any problem whatsoever. All the fluids are perfect. Thanks in advance for any pointers. John Quote Link to comment Share on other sites More sharing options...
tedmister2 Posted February 14, 2007 Share Posted February 14, 2007 If it was me, I would check your ground first, than attempt a jump start. Do you have a battery heater? Good luck ted Quote Link to comment Share on other sites More sharing options...
Cougar Posted February 14, 2007 Share Posted February 14, 2007 I would clean the battery connections with a battery brush and check the fusible links for a bad connection. Quote Link to comment Share on other sites More sharing options...
jon38iowa Posted February 14, 2007 Author Share Posted February 14, 2007 I would clean the battery connections with a battery brush and check the fusible links for a bad connection. Thanks to you both. Battery connections are immaculate and coated with protector, moreover, I tried it two more times this morning and after repeat of my first post, it started like no problem at all. I had a friend follow me to the shop and it now awaits diagnosis. Thanks again. John Quote Link to comment Share on other sites More sharing options...
slunk33 Posted February 15, 2007 Share Posted February 15, 2007 My 92 leg was having starting issues lately. I would try to start it and it would do nothing, no clicks, nothing. The starter needed replaces, I was able to get it done at wholesale so wasn't too bad, around $250. I don't know if that is the same problem you are having, but that was my solution. Quote Link to comment Share on other sites More sharing options...
nipper Posted February 15, 2007 Share Posted February 15, 2007 er um did you check the voltage in the battery? How old is the battery? Also check your starter connections. Can be the starter thats the issue. nipper Quote Link to comment Share on other sites More sharing options...
jon38iowa Posted February 15, 2007 Author Share Posted February 15, 2007 er um did you check the voltage in the battery? How old is the battery? Also check your starter connections. Can be the starter thats the issue. nipper Battery replaced new last Fall, top of the line Napa. The cable look tight and in great shape. I have replaced a starter on '80s american made, moreover, if memory serves me it did not kill the lights or have any effect on the rest of the car. Perhaps cars have changed even more dramaticaly then I thought. Quote Link to comment Share on other sites More sharing options...
nipper Posted February 15, 2007 Share Posted February 15, 2007 Battery replaced new last Fall, top of the line Napa. The cable look tight and in great shape. I have replaced a starter on '80s american made, moreover, if memory serves me it did not kill the lights or have any effect on the rest of the car. Perhaps cars have changed even more dramaticaly then I thought. If the solenoid contacts are shot, yes they can. Good news is that the contacts can easily be replaced. nipper Quote Link to comment Share on other sites More sharing options...
Cougar Posted February 15, 2007 Share Posted February 15, 2007 It may be a coincidence, but the fact that you moved the battery cables and the security lights started flashing means to me that connection to power was made somehow. Perhaps the battery has a internal connection problem to the plates and by placing the right movement on the cables made the connection. Measuring the battery voltage at the posts while the trouble is happening will tell the story if that is true or not. Quote Link to comment Share on other sites More sharing options...
Skip Posted February 15, 2007 Share Posted February 15, 2007 In direct reference to Cougar's excellent observation. I am putting a check mark next to the cable to clamp connection. (not the clamp to terminal connection already addressed) Quote Link to comment Share on other sites More sharing options...
jon38iowa Posted February 18, 2007 Author Share Posted February 18, 2007 Good News: The shop looked it over and all it turned out to be, was a loose ground wire. No charge either:banana: Quote Link to comment Share on other sites More sharing options...
Cougar Posted February 18, 2007 Share Posted February 18, 2007 Good deal. Thanks for the update. Quote Link to comment Share on other sites More sharing options...
