Goatboy Posted November 21, 2003 Share Posted November 21, 2003 What happens if you put regular Power Steering Fluid in the Pump of an EA82?? I just did it! Then heard I wasn't suppose to. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 21, 2003 Share Posted November 21, 2003 it might foam a little. if its just a little, i dont think it would hurt anything.... Quote Link to comment Share on other sites More sharing options...
Goatboy Posted November 21, 2003 Author Share Posted November 21, 2003 Was I suppose to use regular ATF in that pump? Should I drain the resevoir before starting the car? Quote Link to comment Share on other sites More sharing options...
xenongod Posted November 21, 2003 Share Posted November 21, 2003 Nothing most likely...most generic power steering fluids are the about the same as Automatic Transmission Fluid...which I think is what is called for on Subaru power steering units. I know anything and everything about fluids and oils for cars...managed a fast lube for five years...with another eight years of light duty mechanical work...including engine pulls...etc....so..anyhoo...you should be fine...no worries. I don't have power steering...gotta use my muscles to steer...hehhe...take care. Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted November 22, 2003 Share Posted November 22, 2003 Will John deere HY-GARD regular viscosity work? I have used it as ATF with good results in my cadillac. Quote Link to comment Share on other sites More sharing options...
Skip Posted November 22, 2003 Share Posted November 22, 2003 Maybe GB has heard about the power steering in an XT6 This unit MUST use the Subaru special PS fluid. As Xgod says, normal PS fluid in the other Roos will be fine. Quote Link to comment Share on other sites More sharing options...
