April 11, 200719 yr I'm repainting the '78 soon and want to remove the bedliner I put on it. Anybody ever do it? What did you use? Help! Thanks! Mary
April 11, 200719 yr a crud thug might work the best. it'll take a while tho:-\ maybe a chemical will get it out
April 12, 200719 yr its a great tool for removing tough stuff. similar to a wire wheel, but works better and has wider wheels. might be able to use a torch on it as well and burn it off. then wipe with brillo pad.
April 12, 200719 yr That aircraft grade stripper might be worth a shot. Or some sort of automotive solvent/ stripper. I'll make a call to our supplier tomorrow if I can remember it while I'm at work and see what they have to say. Other than that, wire brush on an angle grinder and a ton of time.
April 12, 200719 yr Author That aircraft grade stripper might be worth a shot. Or some sort of automotive solvent/ stripper. I'll make a call to our supplier tomorrow if I can remember it while I'm at work and see what they have to say. Other than that, wire brush on an angle grinder and a ton of time. Thanks! The burning it off sounds kinda fun, but it'll be really stinky.
April 12, 200719 yr Thanks! The burning it off sounds kinda fun, but it'll be really stinky. Yes, mucho ventilation needed. And probably some unhappy neighbors and enviromentalists... With that said if you were closer I'd help torch it off:headbang:
April 12, 200719 yr when i used to work on motorcycles i'd do the torch method with brillo pads to strip the paint/grease off. works great
April 12, 200719 yr Good luck on getting beliner off Mary. They way we do it at work, we use a torch and burn it off but yes, its very stinky and very messy. Plus, it leaves behind a nasty residue that has to be cleaned off before painted.
April 12, 200718 yr Is that a function-specific tool, or just a grinder with a different attachment? Looking at it, it seems the later might be possible, even if that's not what the story is here. Back to the bedliner, I think I'd just get all the loose stuff up and re-spray it. With as thick as you can lay that stuff on, I would think you could get it reasonably level.
April 12, 200718 yr ... Plus, it leaves behind a nasty residue that has to be cleaned off before painted. Yes!, if you wanna do that, Be Careful, Wear Safety Gogles, Gloves & Nose Air Filters... Good Luck!
May 14, 200718 yr Author It's done! http://www.ultimatesubaru.org/photos/showphoto.php?photo=15553&cat=500&ppuser=5798 Here's the verdict. Heat Gun and scraping - works, but is way too slow and tough to scrape off. Torch - smelly, messy, too nasty and pretty expensive to do the whole job. 5F5 Stripper - works, but needs several applications to get results. Too expensive - $40.00 gallon would take 2-3 gallons.. Dad's Easy Spray Stripper - works on the bedliner in one application. A second application is needed to get through the original paint and primer. $20.00 gallon at Walmart. It took less than a gallon and about half the time of 5F5.
