EA81T Springs
How much stiffer than n/a springs are the ones on the turbo cars of this vintage?
check the top link below in Similar Threads.. it should be all there to piece together? good luck.
They are only about 25lbs/in stiffer than a regular EA81 4wd spring, but they are shorter as well. I'll double check my FSM when I get home.
they are so much stiffer that you cant tell a darn bit of difference LOL.
-Mike
?? Actually, you can feel quite a substantial difference....
