opelsuby Posted June 26, 2007 Share Posted June 26, 2007 Arrgh. I finally got the gas tank drained and the line cleaned. New fuel pump, so ready to fire it up. Cranked the engine. Noticed smoke from the engine bay. I quick check and I saw the wires to the alt were not hooked up. i had taken them off because I had to move the alt to gain access to something. O.k. alt wires reinstalled and turn the key....nothing and I mean nothing. Not even lights to the dash. Anyone got a clue as to where to start? An order would be good. See, even those little things you forget can get you. Tis an 81 wagon 4wd Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 26, 2007 Share Posted June 26, 2007 Fusible links? Longshot but perhaps are the battery cables hooked up correct? Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 26, 2007 Share Posted June 26, 2007 I agree with Gloyale. Check the fusible links. The alternator output lead is always hot to the battery and the wire may have grounded out when you tried to start it, causing smoked link. Quote Link to comment Share on other sites More sharing options...
opelsuby Posted June 26, 2007 Author Share Posted June 26, 2007 On what line are the fusible links? Quote Link to comment Share on other sites More sharing options...
opelsuby Posted June 26, 2007 Author Share Posted June 26, 2007 oops. I didn't read close enough. fusible link is in the alt line to batt? Quote Link to comment Share on other sites More sharing options...
Turbone Posted June 26, 2007 Share Posted June 26, 2007 Its a little black rectangular box on the pass wheel well next to the battery. Pull the lid off and you will see the fuses, which are looped colored wires. Quote Link to comment Share on other sites More sharing options...
opelsuby Posted June 26, 2007 Author Share Posted June 26, 2007 Excellent. Much obliged. Quote Link to comment Share on other sites More sharing options...
s'ko Posted June 28, 2007 Share Posted June 28, 2007 I agree with Gloyale. Check the fusible links. The alternator output lead is always hot to the battery and the wire may have grounded out when you tried to start it, causing smoked link. mmmmm smoked link... Hehe Back to topic. When I go to the PAP, I grab the fusible links in the soobs I see. Never had one go out on me, but it never helps to have umm... 20 of them lying around?? BW Quote Link to comment Share on other sites More sharing options...
opelsuby Posted July 2, 2007 Author Share Posted July 2, 2007 No such luck on the little black box. I have two boxes. One is the voltage regulator, The other one I pulled had some goofey wording on the cover like Matsubsta or something. I took the three little srews off the back of that. I found what looks like two little transistor towers in there. Got Plan B? Quote Link to comment Share on other sites More sharing options...
Cougar Posted July 3, 2007 Share Posted July 3, 2007 I'm not sure where the box is for your model. The later models mounted the box on the coolant reservoir. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 3, 2007 Share Posted July 3, 2007 it will be where the small black wire on the battery termnal leads to, at least on an 83 Quote Link to comment Share on other sites More sharing options...
opelsuby Posted July 9, 2007 Author Share Posted July 9, 2007 SCORE!!!!! yes. Follow the positive lead off the battery. Look for the funky little piece with the cloth wire covering. It is only about 2-3 inches long. Less than a foot off the terminal. Pics below. I tried to get the wire connector out. No such luck. I cut a piece of new fusible link wire ( Napa, sppol for less thank $ 6.00) and crimped it in there. Tried the key and all the dash lights lit up and the engine cranked. I ran some fuel line right from the pump to a gas can. Won't fire. Then had wife turn key while I put my hand over the fuel filter inlet. Slight suction. Looks like I might have to elevate the can to get the pump primed? If it runs then I'll reconnect it to the gas tank. Good Plan? Quote Link to comment Share on other sites More sharing options...
