June 29, 200718 yr Is there a way to remove the front struts on my 1987 GL wagon 4wd WITHOUT loosing brake fluid or even opening the lines?Thanks.
June 29, 200718 yr Yes there is. It takes a good set of side cutters or a hacksaw, or what ever. You just cut thru where the line goes thru at the narrowest point. Then bend the top and bottom out of the way and pull the line out.
July 1, 200718 yr or, make 2 cuts and you don't have to bend anything. I like to use a dremel with a reinforced cutoff wheel.
