July 19, 200718 yr Normal H4 lamps are 55 watts, i found some rated 90 to 100 watts. Is it possible to use these or will i burn things (fuse, wires?)
July 19, 200718 yr Well your doubling the wattage, so yes you may cook things. You need to wire in relays and heavier wiring to take the extra load. nipper
July 19, 200718 yr yeah there is a really good chance you will melt the housings even if you upgrade the wiring. Plus it's illegal. Get some narva rangepower +50s (or equivalent), clear the lenses, and upgrade the harness though. If you still want more light get some aux driving lights.
July 19, 200718 yr yeah there is a really good chance you will melt the housings even if you upgrade the wiring. Plus it's illegal. Get some narva rangepower +50s (or equivalent), clear the lenses, and upgrade the harness though. If you still want more light get some aux driving lights.It might be illegal where you live - he lives in the Netherlands so it might be different there. I would agree that you'd need some relays and heavier gauge wiring to make sure you don't melt the connectors.
July 19, 200718 yr Most likely illegal, but on the plus side I think he has glass e-code headlights. So the good bulbs and a better harness would be a good idea.
July 20, 200718 yr Author Yes i have Glass E4 light units and metal reflectors. But i dont want to modify too much. I already have 2x 100w (hella) fog lights completely relayed and heavy wired. I have seen people cleaning their headlights with toothpaste because they become yellowish. I have never seen that over here. Is it because the european light units are different or different weather?
July 20, 200718 yr I have never seen that over here. Is it because the european light units are different or different weather? Your lights have glass lenses, ours are plastic, the plastic yellows over time. Bosch makes an off-road bulb that is 80W/100W (low/high) that I have run in motorcycles. I would not try them in plastic lights, and we have to remember Japanese made headlights are not as focused (or "directed") as european made headlights, turning up the wattage may very well blind on-coming drivers.
July 23, 200718 yr You'll probably be fine. An upgraded wiring harness & connectors with relays isn't a bad idea, but you'd probably be ok.
