July 23, 200718 yr Any one know if the EA81-EA82 oil pans are interchangeable? I need to replace an EA-81 oil pan....
July 23, 200718 yr No, they are very different. Different bolt pattern, different capacity, different gasket. Sorry :-\ Emily http://www.ccrengines.com
July 23, 200718 yr I got a spare EA81 oil pan right now.... (I think, it's in a pile with two EA81 valve covers). I bet you can find one closer than CO though.
July 24, 200718 yr Author OK thanks for the info Emily. Zwedall I will look around the local U-Pull this week for one -but I will keep it in mind that you have one just in case. Thanks.
August 4, 200718 yr Author Ok how about EA-71 to EA-81 oil pan interchange? I found an EA-71 local... No, they are very different. Different bolt pattern, different capacity, different gasket. Sorry :-\ Emily http://www.ccrengines.com
August 5, 200718 yr Ok how about EA-71 to EA-81 oil pan interchange? I found an EA-71 local... I've still got an ea-81 pan laying here.
April 13, 201114 yr Dang it, I don't like resurrecting old threads.... but I can NOT figure out if EA82 oil pans interchange.... There's a SPFI wagon at the junkyard that has a good oil pan, and my XT NA MPFI has a terribly dented one... Just have to make SURE they are the same. Thanks!
