"New" 92 Loyale
Hi, all
Finally found a replacement for "white&rust" 84. Decent 92 4wd 5speed. I asked a few questions earlier and inadvertently posted to new gen forum. Got good answers but still have a couple of mysteries to solve. Now don't laugh, but WHERE IS THE HORN LOCATED??? I can't see it, I know it should be attached to the rad support or nearby. It doesn't work, the fuze is good, so I seriously think it's been removed. (The car has recent paint and bodywork) The other question is (are) what color is the horn harness, where is the diagnostic connector on a 92, and what is the readout procedure? (I have a Haynes EFI book with codes but their procedure doesn't compute) Along those lines, a schematic would be invaluable to me. Lastly, your suggestions for a service manual better than Haynes? Thanks up front 'cause I know you people will tell all:)
Remove the front bumper. Then you can see them, one near each end. I believe there is a relay involved also.
This is pre OBDII. Under the steering wheel there is a plastic panel that goes almost to the firewall. Remove it. There is a about 6" x 8" box that is the ECU. On the front edge is a hole. Get the angle right, and you can see a red LED. It blinks the trouble code (if any).
There is no substitue for a factory service manual. I have an 86 & a 90. Best bet to get one is probably ebay. There are some minor differences between different years.
Dave, thanks for the info. I certainly agree there's no substitute for the FSM (Have 'em for my other toys) and I'll try to get one. I was afraid the horns might have been down there as I found a disconnected 2-wire plug with the wires heading in that direction while I was installing a new park/turn light assy. on the driver's side. Still didn't work. Anyone care to tell me where the relay(s) are? And the diagnostic connector?
hey insted of removing the bumper. Just remove both head lights and it's right there! You can even take them off from there!
I was just tickering with that today!
And yeah the FSM's are your best bet.
PS: I think the diagnostic connector is a big green plug by the master cylender! Ontop by the fire wall. You can't miss it!:)
http://www.ch601.org/engines.htm
Subaru EA82 parts 1 and 2.
comes from a 89 GL FSM, but its 99% accurate to your car; its only a few sections though, scanned and posted by aircraft hobbiest types, so its engine, cooling, etc. Has the complete NA SPFI section though, which is the most important bit.
Many thanks, folks. Last but not least, why is the rear wiper motor as corroded and frozen as the one on my 84, yet the tailgate on this car is not rusted at all? Must be a way to seal the shaft on these things?
I don't know why your rear wiper is so corroded and frozen?? Mine was not.. But as for sealing it. I don't think you can!:confused:
Mine froze up on me after this last winter. Ended up soaking the shaft with some pb blaster and working the wiper by hand for a while with the motor on and it eventually freed up and now moves as fast as the fronts. I plan on putting some kind of grease on the shaft under that cap to try to keep out any moisture.
-Doug
Yeah the gease is pretty much the only thing you can.. Just wash you car more:lol: Keep the salt off it!:lol::grin:
