paulpicard Posted September 11, 2007 Share Posted September 11, 2007 I am ordering a rear wheel bearing assy for my "new" 92 Loyale 4wd. My local auto parts store (who are very good - not Autozone or Canadian Tire type) quoted me on an SKF part# GRW142 at Can$110 (US$100) So here I am double-checking as I only have a Haynes manual covering EA81 and early EA82's. Is this all I'm gonna need or are there seals and other parts involved, and is the price reasonable? Quote Link to comment Share on other sites More sharing options...
Reveeen Posted September 11, 2007 Share Posted September 11, 2007 All I have is a NTN number K8000-90152 @ $60 US (List $106) There are two seals inner (brake side), outer (diff side) Inner seal (CR $5.40) or Subaru $17.xx ($8 trade price) No idea on the outer, should be similar $ wise Amazon.com will sell you a GRW142 for $52.81 US http://www.amazon.com/SKF-GRW142-Hub-Unit/dp/B000ELW8HS There is cheaper on the web if you look. I have no idea what the dealer wants for a bearing Note: these are press-in bearings Quote Link to comment Share on other sites More sharing options...
markjw Posted September 11, 2007 Share Posted September 11, 2007 Partsamerica.com is usually really cheap. They want $105 for a set of inner and outer bearings and a few dollars for the seals. Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 11, 2007 Author Share Posted September 11, 2007 Thanx reveeen and markjw. Anyone got part numbers for these seals? Quote Link to comment Share on other sites More sharing options...
Reveeen Posted September 11, 2007 Share Posted September 11, 2007 They want $105 for a set of inner and outer bearings and a few dollars for the seals. There is only 1 bearing! Quote Link to comment Share on other sites More sharing options...
2K4 STI Posted September 11, 2007 Share Posted September 11, 2007 Might check on http://WWW.RockAuto.com Quote Link to comment Share on other sites More sharing options...
RONAN Posted September 11, 2007 Share Posted September 11, 2007 I did one last year. The bearing cost me $38 and change and the seals were $5 & $7 I think. There is only one bearing. Quote Link to comment Share on other sites More sharing options...
markjw Posted September 11, 2007 Share Posted September 11, 2007 Oops. I guess the fwd has the inner and outer. Here's a link to what you may need. http://www.partsamerica.com/productdetail.aspx?MfrCode=SKF&MfrPartNumber=GRW142&PartType=186&PTSet=A Quote Link to comment Share on other sites More sharing options...
Reveeen Posted September 11, 2007 Share Posted September 11, 2007 Thanx reveeen and markjw. Anyone got part numbers for these seals? I don't have them (buried in paperwork), I could call Subaru this AM if you like, I really don't trust aftermarket (for seals). If your parts folks are hooked up with the "Best Buy" group (wholesalers out of Toronto) you can source Beck Arnley through them. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted September 11, 2007 Share Posted September 11, 2007 There is only 1 bearing! Some EA82(early, 85 for sure, possibly till 87 or 88) have 2 seperate tappered roller bearings. But IIRC you can replce that style with the single large roller bearing. For a 92 It should just be one in there already. Quote Link to comment Share on other sites More sharing options...
paulpicard Posted September 11, 2007 Author Share Posted September 11, 2007 Thanks everyone. Reveeen, appreciate the offer, but I'm picking up a heater resistor block at the Penticton dealer so I believe I'll get the seals from them as well since they seem to be inexpensive. FWIW, the resistor block is C$48.00 at the dealer. Quote Link to comment Share on other sites More sharing options...
