Documented: The 1970 FF-1 Project car...
  • Replies 1.6k
  • Views 329.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • OMG! FINALLY! She will live again!  THE HOLE.... IS GONE! (more photos to come soon - i just opened the box, crappy phone pix!)       Now the fun begins.
  • SEAT PHOTOS!   Again, seats are from a 1982 Mazda GLC. They were from the original owner, who'd removed them from his car when new to install Sparco seats. Sat in his basement for 30 years waiting
  • Horns work!  (BEEP BEEP you've been warned!)   click here for video       Engine will be back inside of the car TODAY
Posted Images
I can't tell you what the bushings are, but I can tell you this:
"Seller will not ship internationally."
Edit: I totally did not see page 26 when I posted this...
Mine arrived in the post this week. one white one, one red and a yellow one, to go with the 2 green one's and a 1/63 white coupe.
Thierry
Thierry
How much was the shipping?
I think the shipping came out to be about $10 US for all three,
Thierry
Day 11:
Been a little while since my last update, expect less frequent updates during the winter...
Anyway, I got the wiring harness completely removed from the car now. I also removed the radiators and the support, and started working on prep to remove the engine/transmission.
I also picked up a couple parts I plan on using for the engine and have some comparison photos here for you... One item I got was the 32/36 Weber Carburetor I just got from Jibs, and also an intake manifold from an EA63 (courtesy fisnindiot) which fits the same as the current intake manifold but with more flow (both air AND coolant flow) and is capable of running the Weber carburetor due to the bolt pattern (which is smaller on the EA61 intake manifold as I found out).
Enough talk, here are the photos:
Wow not too shabby. I just recently picked up a bunch of old Subaru FSMs from the great bay of E for the FF1s, for the 72 or so but still it has lots of great info in them. Lemme know if there's anything I can help with like that harness:banana:
You have a project ahead of you. Keep up the good work though and you'll have a sweer\t ride when its all done.:)
That should be a quick little car with that carb and intake setup! Really cool project indeed!:slobber:
Well I went to remove the engine from the car today (but not the transmission, still has the brake lines/e-brake/axles/etc. connected) and it turns out the bottom engine-transmission bolts are blocked by the inboard brakes :( I'll have to remove it as one unit, or figure out a way to move the engine enough to unbolt it...
What if you unbolt the engine crossmember from the car and the suspension that bolts to the unibody and drop out the engine/tranny/suspension as one unit and strip it down outside the car? Just a thought...
Thats a possibility, but i'd also have to unbolt the steering column and still unbolt the brake lines/e-brake, etc.
Kosta, in my tool box i have a special tool to undo the bottom 2 nuts on the trany/ engine, basically just a 17mm ring open spanner heated and bent into a z shape to clear, can still use the spanner on other jobs even if it is bent. but before i made the tool i used to jack the engine up enough with the trany to access the nuts.
Thierry
Ill try jacking up the engine and see how that goes. Thanks for the tip, I was thinking a bent wrench would work but don't really have a good way of making one. Jacking it up should work for now.
Remove the starter it gives you more room if you haven't already.
Thierry
Hey, i know this isnt really on topic, but I was wondering if anyone knows if you can put 1100 or 1300 heads on an ea81?
Anyway, back on topic, sweet ride man! If you want a decent rendering of your idea for the completed car, let me know and i'll sketch somethin up!
