Documented: The 1970 FF-1 Project car...
if you can get a pic of the threads, you might be able to retap them and fix them. Only way you're gonna fix it...
  • Replies 1.6k
  • Views 330k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • OMG! FINALLY! She will live again!  THE HOLE.... IS GONE! (more photos to come soon - i just opened the box, crappy phone pix!)       Now the fun begins.
  • SEAT PHOTOS!   Again, seats are from a 1982 Mazda GLC. They were from the original owner, who'd removed them from his car when new to install Sparco seats. Sat in his basement for 30 years waiting
  • Horns work!  (BEEP BEEP you've been warned!)   click here for video       Engine will be back inside of the car TODAY
Posted Images
I'm contemplating cutting off the bad first couple of threads (since they are "squished" which made them wide and too narrow to thread through) but it would put it close to the hole that the pin goes through...
I already used that procedure with a couple of other spots on the suspension I fubared where clearance wasn't an issue, but with these there is less wiggle room.
You can always grind the diameter of the damaged section down closer to where it was and then either use a thread file of the correct pitch and do it by hand or use a re-threading die. You should be able to fix them without having to cut any material off. Working with some other techs over the years has improved my skills in damaged thread repair:grin:
BTW I have been watching this thread from the beginning and it is looking great. Keep up the details and pics!
Hmm, thread file, I'll have to check that out. Someone mentioned a thread die elsewhere and that seems like an expensive contraption.
This one isn`t too pricey.Looks like it has your size.Should be able to buy just one thru a local jobber too.
http://cgi.ebay.com/45-PCS-LARGE-TAP-DIE-SET-TUNGSTEN-STEEL-TOOL-METRIC_W0QQitemZ400008597513QQihZ027QQcategoryZ58227QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
To fix the threads, just file/grind down the mushroomed part and run a die down it to fix the threads.
Oh, on a side note, I've been trying to reassemble my rear brakes today and i've found all the parts I picked up that were supposedly for the FF-1 (rear brake linings, brake cylinder, brake spring kit, etc.) all are wrong :(
I figure its because the suspension is actually a Wagon rear suspension and not a sedan rear suspension, which means all that stuff isn't compatible...
Man that sucks!! So is the right stuff available? Where can you find it?
I just found some wheel cylinders on ebay that look correct. Apparently the ones I bought before were for the front (so I have 4 fronts, no rears).
I've found the pins and springs for the brakes now, although one of the springs is not availible anymore, the other still is. However, brake shoes for these rears are non-existent :( (part number: 625301150 or 625300140)
If that picture is correct... Nope.
And they need to be "wagon" ff-1 rear brakes. The coupes/sedans are wrong.
Looks like he uses the same picture for many shoe sets.Bet he has what you need.
I might have those brake parts but don't hold your breath.
find a shop that relines brake pads and have them do it for you specail. its not that bad price wise(i have to do this on my 73 with drums up front) anyway you might look down that road.
Sorry the Snap-On link didn't work. Here is a picture of it from the site (seems to be working now).
find a shop that relines brake pads and have them do it for you special. its not that bad price wise(i have to do this on my 73 with drums up front) anyway you might look down that road.
The linings are OK right now thickness wise, but I am concerned about down the road if I ever have to replace them... I'll probably have to go that route (unless someone like moosens has a pair laying around, or I can find some off of a parts car)
Might be incorrect,but, 1st Subaru says both of those numbers are still good. $19/set
https://www.1stsubaruparts.com/part_number.html
The numbers are still good, but they are not "active" and not availible. If I tried to order them, they will just be canceled (I work at a Subaru parts department FYI)
I got the tie rod threads fixed today :banana:
My shop foreman had a whole die set, and another tech gave me a hand, got it done nicely :)
However, I did discover one of the front wheel bearings is shot :-\ Luckily I have a spare, and the tools and help to do the job! :banana:
Thought you guys might find these photos interesting I found last night on a JDM blog: http://minkara.carview.co.jp/userid/215699/car/105463/profile.aspx
yes, those are HID's! He shows how to install them in the blog, lol!
those are the SSR wheels I saw recently for sale on the yahoo auctions
check out his awesome exhaust setup!
LOL! Neon green with funky black painted hood...
...but check out his seat setup, I think i'll do something similar.
That Exhaust looks Just like the Factory sports exhaust I have on my GSR :)
Small update:
I just rolled the front fenders, repaired a bend on the passenger door (got a set of bodywork hammer/dolly's from Harbor Freight), and reinstalled the brake shoes on one of the rear brakes after rebuilding the original brake cylinders (I have one that needs a stud tapped though since it broke off, I basically re-used the original housing but used the internals from some of the "rebuilt" cylinders I found on ebay).
I have decided I need to buy my tires before the end of the month, the sales tax is going up next month here in California! I haven't found a place to repair the wheels yet, it looks like I'll have to go with the expensive "mobile repair" wheel specialist...
