LSD or Not
Both rear tires will turn in the same direction when you are rotating one side. Otherwise the other side may turn but in the opposite direction on the non lsd unit.
LSD on the rear diff tag. if not, turn one side stub. if the other side turns the same way it's LSD, if it turns the opposite way it's not.
Thanks Guys,Ill check the rear Diff tag and if its not there ill try with the rears off the ground.
What Models and years came with the LSD?
Late '80s RX models; option on '88 and '89 Turbos. Maybe some others.
Cleaned all the crud off the rear diff and it is a LSD. :grin:
what a hysterical thread, this should be in the funnies or something.
that's great you got it already! nice score huh!
