FWD Justy Trans Removal
I think Justy belongs in Old School, so here it goes.
I need to pull the trans in a '90 FWD justy I just picked up, but I'm not sure if I should just pull the trans by itself or if I'll be better off pulling the motor and trans together. Thoughts?
Keith
I tend to dissagree - I've done a number of FWD transverse transmissions and clutches, and I've always just pulled the tranny - both auto and manual. Usually a lot less to disconnect and once you support the engine either from above or with a jack, and then pull the axles the tranny will just drop out.
