archemitis Posted November 28, 2007 Share Posted November 28, 2007 yes i searched, and it worked so well, i found nothing. my wifes xt6 has a good heater core, and both hoses leading to it are hot as can be. my hot to cold selector moves, and operates the white plastic piece it is attached to, but no heat blows out of the vents. the blower does work though. how does the xt6 heater work, my core is hot and only cold air blows, should i take the dash apart and look for a broken vac solenoid, or just wire a trap door shut or something? i've never had a xt6 dash apart, so i need some advise. thanks oh ya, my wife is starting to hate subarus now:confused: Quote Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2007 Share Posted November 28, 2007 Drive an old car, it will have faults. There are a few ways that you can loose heat. 1- The heater control cable has come off the lever at the heater box. It should be obvious to see if you look under the passenger dash side of the car. 2- Does the engine reach operating temperiture. If it doesnt the t-stat may be stuck open. A bad radiator cap may contribute to it. 3- The most hideous, low coolant level. One can be its just low, on the bad side it can be a head gasket. I'm voitng for #1 nipper Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 28, 2007 Author Share Posted November 28, 2007 sorry for my long winded post, but its none of the above. the white plastic adjuster by the throttle pedal (that is controlled by the cable)moves, im thinking its broken where i cant see it. im wondering if xt6 uses vac to move a flap in the heater system, like my other ea82s and ea81s. my core is hot and has good flow through Quote Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2007 Share Posted November 28, 2007 well DOES it reach operating temperiture? how old is the water pump. You can't just say no and leave it at that otherwise we cant help you. Tell us what you HAVE done to find the problem. We arent mind readers nipper Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 28, 2007 Author Share Posted November 28, 2007 i elaborated after i edited my second post. Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 28, 2007 Author Share Posted November 28, 2007 i appreciate the attempt at help, but i think you need to read my whole first post, not just the first and last sentences. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2007 Share Posted November 28, 2007 Subaru heaters use a mixing door. This mixes hot and cold air to give you the temp that you want. The good side to this is that its simple, the bad side is that it is hard sometimes to get a good temp (the controller has a heat spot. Now since you see the cable moving the arm of the mixing door, disconnect that cable and move the arm by hand. There are a few possabilities here. One is that the cable is out of adjustment and not moving the door enough. This can be due to a broken or missing retaining clamp on the cable housing at either end of the cable. The cable should move as soon as the handle moves. Next if you move the lever under the dash by hand, you should be able to hear the door "thunk" inside the heater box. Subarus have used cables for temp, and vacume motors (or newer subarus electric motors) to control direction of the air. If you can move the air from heat to def to dash then those are fine. By default if those doors have a issue the car goes to defrost only mode. Now you say the heater core gets hot, but how can you tell? The inlet and outlet hose is not going to tell you. What feels hot to the hand, may not be hot enough to produce heat. Also when was the last time the system was flushed and serviced? I am sorry about not reading your post like you think, but i DID read it, and have learned in 20 years to ask direct questions, as sometimes people leave out details. Like i said before, how is the cooling system? Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 29, 2007 Author Share Posted November 29, 2007 the cooling system is in tip top shape, i had it idling for 30 mins and the rad fan comes on when it should, and the thermostat opens at 195degrees... its gotta be a door, and i think its kindof xt specific thing Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 29, 2007 Author Share Posted November 29, 2007 and when i say hot i mean hot... one of those thermo laser thingy told me i also poured water through the core so its full, has good flow and is as hot as my thermostat housing, around 180 Quote Link to comment Share on other sites More sharing options...
nipper Posted November 29, 2007 Share Posted November 29, 2007 good luck, im unsubscribing from this thread, as i told you how to check the air mix door. nipper Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 29, 2007 Author Share Posted November 29, 2007 i got no thunk hopefully somebody with an xt can tell me if i have a vac operated door, or just a manual one Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 29, 2007 Share Posted November 29, 2007 You may want to check over at http://www.subaruxt.com A great bunch of folks, many of them with Xt experience since the cars were new. Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 29, 2007 Author Share Posted November 29, 2007 ya, i was hoping grossgary, or kingbobdole would see it over here. of course none of my chiltons cover that part. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 29, 2007 Share Posted November 29, 2007 ya, i was hoping grossgaryhello? we have the FSM's available over at the XT site though. you could down load them and look, but i'm sure you're not interested in all that. i would definitely search at the xt site, maybe someone else has experienced this before. it'll be identical to an 87+ XT and should be the same style set up as an EA82. check into this, see if it helps: the clips for the control arms for the heater doors. They are a white plastic that look like a CLAM shell kinda with a plug on back that snaps into the door arms. Then you adjust the control that runs off the elec motor by snapping the arm in the right place with the door. So you would push the defrost switch and the motor would move the control then you open the door and snap the arm into the CLAM style holder. FYI folks The newer styleclip which they call a connector is Subaru part number 772034290 Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 29, 2007 Author Share Posted November 29, 2007 downloading stuff is cool... thanks! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 29, 2007 Share Posted November 29, 2007 i just edited my last post...might want to look it over again. quit checking back so quickly! Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 29, 2007 Author Share Posted November 29, 2007 hahahaah im at work, so im getting payed to check back! wahoo! Quote Link to comment Share on other sites More sharing options...
archemitis Posted November 29, 2007 Author Share Posted November 29, 2007 doh, the links are there, but nothing behind them Directory Listing Denied This Virtual Directory does not allow contents to be listed. Quote Link to comment Share on other sites More sharing options...
