January 5, 200818 yr I'm going to tackle the front oxygen sensor tommorow. I have a 22 mm wrench and a can of PB blast. Is that all i need?
January 5, 200818 yr Youll need a couple cans of Steinlager to loosen up first then earmuffs for any children in the vicinity. Unless i just got unlucky and every O2 sensor ive changed was welded in place by the previous owner.
January 5, 200818 yr Youll need a couple cans of Steinlager to loosen up first then earmuffs for any children in the vicinity. Much easier to leanr how to curse in latin nipper
January 5, 200818 yr I got mine out pretty easy. I started the car for a minute or two before hand. Enough to warm it up but not to hot. I used a hammer to smack the wrench which worked brilliantly!
January 6, 200818 yr Yes warming the exhaust for a couple minutes has always been the thing that got them to finally break loose after a good Kroiling.
January 7, 200818 yr Somehow in latin it just doesnt sound as bad http://en.wikipedia.org/wiki/Latin_profanity nipper
