January 21, 200818 yr Help! My Legacy is revving up when it is in neutral or when I put the clutch in to shift gears. When I've got it in gear, it seems fine. This started two days ago when the temp. in Duluth went sub-zero! Something stuck? I appreciate any advice you can offer.
January 21, 200818 yr What happens wehn you stop in gear and just hold the clutch in at a red light. Does it still rev? Usually the Idle Air Control Motor controlls the idle speed, It can be dirty or frozen. nipper
January 21, 200818 yr Check your floormat. It might be dragging on the pedal (seriously!) This happened to me once, and I've seen at least one other post about it here. Failing that, play with the throttle body by hand to see if the cable or throttle plate is sticking.
January 21, 200818 yr Author When I depress the the clutch pedal, it revs up, even when it's in gear. What happens wehn you stop in gear and just hold the clutch in at a red light. Does it still rev? Usually the Idle Air Control Motor controlls the idle speed, It can be dirty or frozen. nipper
January 21, 200818 yr Revs how high (RPM)? Does it still do it when the engine is fully warmed (based on the temperature gauge)?
January 21, 200818 yr Author Actually, I don't have a tachometer in my Brighton. That makes it pretty tough to answer your first question, but it seems to reach a certain level and stay there. As for the second question: Yes, it does this even after it's at normal operating temp. Revs how high (RPM)? Does it still do it when the engine is fully warmed (based on the temperature gauge)?
January 29, 200818 yr Author Well, when I peeked under the hood at the throttle body, it looked as if one of the pulleys had gotten stuck on the rubber cap that covers the tube that feeds the wire to the assembly. The rubber cap was still stuck in the pulley. I guess I was lucky! Thanks to all who posted. I hope I didn't waste your time. --D-- Actually, I don't have a tachometer in my Brighton. That makes it pretty tough to answer your first question, but it seems to reach a certain level and stay there. As for the second question: Yes, it does this even after it's at normal operating temp.
