Custom exhaust
So i have a 92 loylae wagon FI and i need to do some repairs on the exhaust. I thought up a custom idea where you do 2 pipes 2 mufflers and maybe cats. That way you would have a true dual exhaust! Good idea? Bad idea? Let me know Thanks! :headbang:
As long as you still retain the crossover pipe at the front. Without that, your power will suffer. I also wouldnt run pipe much larger than stock dia. or your low-end will go in the toilet.
Don't know if it is all the biology I have been reading, but that looks like a massive X chromosome. Skip, how does it sound?
it has a very nice rumble
ask Meeky Moose he and Scrapdaddy heard it.
Lost no low end, feels better through the entire rev range
It also has a Weber conversion.
  • 3 weeks later...
Hey Skip how do you have your PCV system hooked up? I see a breather on the passenger side but i cant see whats going on on the drivers side. Is it just going straight to the pcv?
It's "T"'d into the hose for the remote breather (air filter).
I think this is the line you mean, it used to
run to a fitting on the lower
part of the air cleaner.
I added the remote breather (pictured )
to keep "gunk" out of
the air filter for the Weber.
Hope this helps.
