April 9, 200818 yr Author http://i288.photobucket.com/albums/ll197/ffranken/MVC-917F.jpg http://i288.photobucket.com/albums/ll197/ffranken/MVC-916F.jpg
April 9, 200818 yr Wow! Looks fantastic. Its hard to tell from the pic's, but it looks to be a Very rust free car. Great Score!
April 10, 200817 yr Cool. If I may advise you,please...take the fenders off , remove the foam strip crap that will be found on the back side of the fender where it meets the unibody. You can see the start of that rust that occurs on the top of the fenders on your driver's side.
April 11, 200817 yr Author Cool. If I may advise you,please...take the fenders off , remove the foam strip crap that will be found on the back side of the fender where it meets the unibody. You can see the start of that rust that occurs on the top of the fenders on your driver's side. Thanks, I'll definitely check that out. it seemed like a weird area to be seeing rust.
April 11, 200817 yr Thanks, I'll definitely check that out. it seemed like a weird area to be seeing rust. Is that just surface rust on the fender, or is it something a little deeper?
