edjhover Posted May 1, 2008 Share Posted May 1, 2008 anyone know how to troubleshoot p170 code fuel trim malfunction bank 1? Quote Link to comment Share on other sites More sharing options...
nipper Posted May 1, 2008 Share Posted May 1, 2008 anyone know how to troubleshoot p170 code fuel trim malfunction bank 1? Which subaru what year what engine how many miles. It really is impossible to start to daignose without this information. A shot in the dark O2 sensor. Quote Link to comment Share on other sites More sharing options...
edjhover Posted May 1, 2008 Author Share Posted May 1, 2008 2000 legacy gt 2.5 limited, 135000miles. P170 code. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 1, 2008 Share Posted May 1, 2008 Yup your due for an O2 sensor. nipper Quote Link to comment Share on other sites More sharing options...
edjhover Posted May 1, 2008 Author Share Posted May 1, 2008 Yup your due for an O2 sensor. nipper replaced on 2 other times same side, but had a code for it...right side of vehicle. you think maybe the other sensor is ready then? Quote Link to comment Share on other sites More sharing options...
nipper Posted May 1, 2008 Share Posted May 1, 2008 Did you use on OE sensor of aftermarket? nipper Quote Link to comment Share on other sites More sharing options...
OB99W Posted May 2, 2008 Share Posted May 2, 2008 2000 legacy gt 2.5 limited, 135000miles. P170 code.Scroll down and read the "Similar Threads". Common problems when P0170 is generated are exhaust leaks, intake leaks, fuel pressure issues (high or low), defective engine coolant temperature sensor (CTS) or intake manifold pressure sensor (or airflow sensor). Basically, the P0170 code indicates the ECU can't compensate enough to get an appropriate A/F mixture. I'd look at the intake first for loose connections, since that's probably the easiest. If you haven't replaced the fuel filter recently, you might consider that. An OBD-II scan tool could be used to determine whether the fuel trims are severely to the rich or lean side, which could help determine a more-likely culprit. Since fuel trims are compensating adjustments, being very rich (positive) means the engine is running lean, while very lean (negative) is an effort to deal with a rich-running condition. None of the above is to say that a bad front O2 sensor isn't causing the problem, but that there are other possibilities. replaced on 2 other times same side, but had a code for it...right side of vehicle. [...] Which engine, again? Quote Link to comment Share on other sites More sharing options...
nipper Posted May 2, 2008 Share Posted May 2, 2008 he said it an above post, 2.5L nipper Quote Link to comment Share on other sites More sharing options...
OB99W Posted May 2, 2008 Share Posted May 2, 2008 he said it an above post, 2.5LYes, but he also referred to the "side" (not "front" versus "rear"), which would imply an engine that had a sensor for each bank. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 2, 2008 Share Posted May 2, 2008 Yes, but he also referred to the "side" (not "front" versus "rear"), which would imply an engine that had a sensor for each bank. well the 2.5 has two banks of cylinders I've seen it refered to this before, and i am not sure why. It can just be a generic OBDII code for a ailing o2 sensor as opposed to a dead one. SUbaru doesnt have any bank 1 or bank 2 sensors on the 2.5L, but this code does come up on them anyway. nipper Quote Link to comment Share on other sites More sharing options...
frag Posted May 2, 2008 Share Posted May 2, 2008 I've always thought bank 1 meant the front sensor and bank 2 the rear one. But what do I know... Quote Link to comment Share on other sites More sharing options...
OB99W Posted May 3, 2008 Share Posted May 3, 2008 The code definitions with a 2.5L usually refer to bank 1 sensor 1, or bank 1 sensor 2 -- sensor 1 being the front, and sensor 2 the rear. Bank 2 references would be expected with the 3.0L H-6, since it has a sensor for both bank 1 and bank 2. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 3, 2008 Share Posted May 3, 2008 Ever notice how there is never a 2nd national bank? hehehehe Quote Link to comment Share on other sites More sharing options...
OB99W Posted May 3, 2008 Share Posted May 3, 2008 Ever notice how there is never a 2nd national bank? hehehehe It's a good line, but somebody took advantage of it:https://www.secondnational.com/ EDIT: Apparently, quite a while ago... http://freepages.history.rootsweb.ancestry.com/~butlercounty/secondnationalimage.html 2nd EDIT : http://www.thirdnationalbank.com/app/index.jsp Quote Link to comment Share on other sites More sharing options...
