May 6, 200817 yr Been searching the forums and all over the internet in general with no luck. Thanks in advance.
May 6, 200817 yr 85,86 is an excact replacement 87+ will work and bolt in, but the headlight adjusters will interfere with the grill, very slight bending/cutting would be needed.
May 7, 200817 yr Gloyal is correct, '85 and '86 are exact replacements. I've used '87 and later by just bolting in the bracket to the fender which the same for all years and then using a tie wrap to secure the inner support. No cutting or bending required. The other althernative is to remove the headlamp from the '87 or later bracket and install it in the '85/86 bracket. That's a bit of a pain but it can be done.
May 7, 200817 yr Author Thanks for the advice, hitting the pull and save this week and if they have any, I am all over them, plus some other items.
