June 2, 200817 yr Will seats out of a 01 Imprezza direct bolt into a 91 Subaru legacy? Thanks Sorry, but I can't say for sure from experience..I have heard it Does Not
June 3, 200817 yr Author Sorry, but I can't say for sure from experience..I have heard it Does Not Thanks for the info I will go with this if I don't hear any thing contrary.
June 3, 200817 yr No but if there are a great deal, you should pick them up for my 98 Impreza OBS. Larry
June 3, 200817 yr I thought they would work same bolt pattern...? People put 02 WRX seats in 92 Turbo legacy so I dont know why it wouldnt work.
June 3, 200817 yr yeah they'll fit perfectly. 02+ seats also fit but result in a raised seating position.
June 3, 200817 yr You have to swap out the seat belt ends or whatever they're called. But yes, direct bolt in.
June 3, 200817 yr You have to swap out the seat belt ends or whatever they're called. But yes, direct bolt in. Well, those seat belt ends are riveted into the seat mounts. They'll need to be drilled out.
