flat4fan Posted July 1, 2008 Share Posted July 1, 2008 Hi, I tried the search and faq's and found nothing on this. My wifes 06 legacy has an abs light issue, sorta. It lights like normal upon engine start, then goes out like normal. She then drives to wherever and puts it in park, leaving engine running. (Like the post office) Then when she puts it back in drive, the ABS light comes on and will stay on for the remainder of the drive. Car has 23k and no other problems as of yet. (Hoping to keep it that way for a good long while) Anybody ever hear of this problem before? Would it throw a code? Thanks. Flat4Fan Quote Link to comment Share on other sites More sharing options...
OB99W Posted July 1, 2008 Share Posted July 1, 2008 Is it only the ABS light that comes on, or does the brake warning light also illuminate? Quote Link to comment Share on other sites More sharing options...
flat4fan Posted July 1, 2008 Author Share Posted July 1, 2008 It's only the abs light. Quote Link to comment Share on other sites More sharing options...
sea#3 Posted July 1, 2008 Share Posted July 1, 2008 Going to have to go to the dealer and get them to scan the code SEA#3 Quote Link to comment Share on other sites More sharing options...
flat4fan Posted July 1, 2008 Author Share Posted July 1, 2008 That's what I was afraid of. Well thanks anyhow. Quote Link to comment Share on other sites More sharing options...
Durania Posted July 1, 2008 Share Posted July 1, 2008 That's what I was afraid of. Well thanks anyhow. Why are you worried? It should be under warranty. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 1, 2008 Share Posted July 1, 2008 warranty? i had ABS issues and found everything i needed here, including links to Subaru's ENDWRENCH website with detailed instructions on pulling the codes myself. just jumper a wire in a harness plug that's right above the gas pedal and the ABS light blinks the code to you. it was very easy to do. mine ended up being a front ABS sensor, i replaced it and all was well. not sure the 2006 models are the same, haven't had to do one of those yet (shouldn't have to!??!?!?! is probably what you're thinking too!!!) my suspicion is that the tone ring or sensor are dirty or fouled. the sensors are magnets, if they some how come into contact with metal they will attract all of it and i imagine that miffs them up. it may be as simple as being dirty. But - being a new car you need to read the codes, either yourself or have the dealer do it. new cars aren't subject to typical wear&tear stuff so they're causes tend to differ from older models. Quote Link to comment Share on other sites More sharing options...
flat4fan Posted July 2, 2008 Author Share Posted July 2, 2008 Why are you worried? It should be under warranty. Yes it is, I just didn't want to go back to them. But I may have to. Quote Link to comment Share on other sites More sharing options...
ericem Posted July 2, 2008 Share Posted July 2, 2008 Another possibility is low voltage so maybe a faulty battery or alternator. Because when you put it in D the rpm's have a small drop which means the alternator is not regenerating as much voltage. Many possibilities I guess... Quote Link to comment Share on other sites More sharing options...
